It is currently Sat May 25, 2013 3:01 am
CT17 input problem
norman ramsey
Post Wed Aug 03, 2011 5:51 pm
CT17 input problem
My CT-17 has an input problem. This is a follow up post.The 5.6 volt supply for the input indicator is not working. I think the source is on the FL828 board out of the cathode of D455. The voltage does not arrive at D410. I re-soldered the junctions around the components around the supply. The voltage came back up. I started re-assembly of the preamp by installing the FL828 then checking the voltage and to my surprise it was gone again. I would appreciate help with this problem. I was incorrect on my previous observations. As I have stated the led indicators on the input board work a while then quit. I am open to any suggestions.
Post Wed Aug 03, 2011 7:28 pm
Re: CT17 input problem
Junk it! Actually I'd sell it for parts on eBay. There's many other options out there, some much, much better in my opinion. Oh, and WELCOME!! =D>
Post Wed Aug 03, 2011 9:00 pm
I agree 110% with jjptkd. You can do so much better. Welcome Norman Ramsey. Any relation to Dave Ramsey on the radio ? :D
Post Wed Aug 03, 2011 10:39 pm
Or Chef Gordon Ramsay on TV?
