It is currently Fri May 24, 2013 10:45 pm
Carver A-220 Amplifier
• Page 1 of 1
My current system's made up of two bridged A-760x's in front, and A-220 for rear ambience through a Yamaha DSP. I bought all these new, and still have the manuals and packing. The 760's have been rock solid, but the 220 not so much, as went in for warranty repair when nearly new. Well it's dead again, with the green power light on and very dim meter lighting. Changed some system wiring around, with the second 760 now running the rear channels, but gonna fix the 220 eventually. I'm more than capable of these repairs, as been working on electronics for years. Also find the more technical information the better. Have every manual, diagram for the 760's, but very little on the 220. Figuring the 760's schematic's pretty close, but any help would be appreciated, as gonna be a real pain just getting this thing out of it's installation place. Mark
Re: Carver A-220 Amplifier
Mark...I can get the owners but not repair manual...good luck in your search.
Maybe BillD can help you out.....he is a freakin walkin encyclopedia for Carver gear!
Chauss wrote:Maybe BillD can help you out.....he is a freakin walkin encyclopedia for Carver gear!
I second that ! He's a wuss when it come's to the 400 series amps though !
Don't know shit about an A-220 either.
Thanks for the responses, as actually have all the factory user manuals, packing, ext. The 220's were a very limited run, so not many documents on them. Really just got it to physically match the other Carver stuff I have. Guess I'll just pull it apart, starting with the power supply and output transistors. If bad power transformer secondary windings, have to evaluate scrapping it vs a call to Rita. I'm ok for now swapping to different amps, but a shame seeing the dead 220 totally dark. Mark
Give Rolland a call. Rita is no more !
Oregon
Carver Audio Repair Center
Hi-Tech Audio Ltd.
2125 SW 19th St.
Gresham Oregon 97080
503-618-7605 Fax 503-674-8593
http://www.carveraudiorepair.com
Oregon
Hi-Tech Audio Ltd.
2125 SW 19th St.
• Page 1 of 1
