It is currently Sun May 26, 2013 1:33 am
volume and gain control cleaning??
Post Mon Dec 19, 2011 9:55 am
Re: volume and gain control cleaning??
De Oxit. On some pieces you may be able to spray from the outside but removing the cover and getting to the control parts is always preferable. It's also a plus if you blow out the dust while you are in there using an office compressed can cleaner or air compressor and hose if you have one available.
Post Mon Dec 19, 2011 10:33 am
Right on KingMan!
Here is a link found on here that might be of help.
http://www.carveraudio.com/phpBB3/viewtopic.php?f=39&t=4055&hilit=Deoxit
Post Mon Dec 19, 2011 10:56 am
I recommend the 100% solution with the needle applicator versus the spray; MUCH more precise. It's expensive, but worth it & lasts forever.
Post Mon Dec 19, 2011 7:59 pm
Jump in there.... Good luck!!! =D>
