It is currently Thu May 23, 2013 12:55 am
Carver C1 fuse
seand1
Post Mon Mar 04, 2013 7:16 pm
Carver C1 fuse
Bought my preamp new in 1985 along with an M200t amp.
The last time I used it, maybe 10 years ago, there was a loud buzzing sound.
I shut it off and haven't plugged it in since.
Today I removed the bottom cover and noticed the fuse was blown.
The fuse says 250v 1/4. No other numbers.
May be a dumb question but does that mean its a 1/4 amp fuse?
Post Mon Mar 04, 2013 7:36 pm
Re: Carver C1 fuse
Yes. For a 120v service, it's a quarter amp fuse.
A preamp is a very light load. It should not be upped to a higher value in an effort to keep it from blowing.
Very likely, the sound you heard previously means it's past time for it's normal maintenance. Electrolytic capacitors have a life of about 7-10 years. The C-1 runs fairly cool and should expect a reasonable life towards the upper end. Anything more is borrowed time and a gift. A lot of folks around here have had their units serviced due to the age. Expected and well worth it if you have an audio system you enjoy!
seand1
Post Mon Mar 04, 2013 8:07 pm
Re: Carver C1 fuse
ok,
thanks for the information
