Help with Repair Carver C-1000 Receiver
dbclocks
Post by dbclocks » Sun Aug 03, 2014 5:55 pm
Hi,
I would appreciate some assistance in my efforts to repair a Carver C-1000 Receiver. Someone worked on the receiver previously without success and I told a friend I would take a look. A schematic doesn't appear to be available but if someone has it and would like to share? Also, it appears two transistors, Q220 & 221 were replaced and possibly substituded with a different part. I would like to make sure the parts are correct, The part# installed is IRFZ44 for both locations. Also, what are the correct values for resistors R247 & R255 which are connected to Q220. Thanks
Q220, Q221, R247 & R255 located on left side of Amp PCB.
Re: Help with Repair Carver C-1000 Receiver
Post by TNRabbit » Sun Aug 17, 2014 2:04 am
Sorry no one has gotten back to you on this. There are no schematics available for that unit; it's usually considered to be a boat anchor if anything goes wrong...
You might try Rolland at HiTech Electronics in Oregon....
fill35U
Post by fill35U » Mon Aug 18, 2014 1:17 pm
I couldn't find a service manual or schematic, either.
Interesting that it's a FET amp- unique among Carver?
IME gate drive resistors are around 5-30 ohms, but I don't have experience with FET audio amps. The gate resistors control both turn-on and turn-off times. I'd guess in a linear application, the min turn-on is more important. Probably better to err on the side of too big! Minimal wattage.
Good luck! I always liked those C-1000's foreshadowed Sunfire styling.
Post by Toy Maker » Mon Aug 18, 2014 3:55 pm
I'd check with Bill... He is one of the very few that might be able to help on this one.
It was built BY Sunfire FOR Carver....
http://www.flannerysvintageaudio.com/
Post by jjptkd » Mon Aug 18, 2014 4:44 pm
I've asked Bill about these before, pretty much like Rabbit said, boat anchor if it breaks. I know Bill won't work on it anyway, maybe Rolland at Hi-Tech?? :-k :-k
Oppo Sonica DAC
Sunfire TG-III
Klipsch Chorus II
