M-500t won't shut off!
briandarflinger
Post by briandarflinger » Tue Feb 20, 2018 11:48 am
Hello everyone- Its been awhile..
So- My M-500t is on as soon as its plugged in,, and the only thing the power button does is turn the meter lights on and off- but the Amp is always on. Anyone dealt with this issue?-
Thanks in advance
-Brian
(4) M-500t
(4) M-1.0t
sunfire theatre grand
Yamaha NS-100m
Klipsch forte II
Robert R
Re: M-500t won't shut off!
Post by Robert R » Tue Feb 20, 2018 9:32 pm
Those amps are always on unless actively shut down - not by just the switch, but by circuitry that the switch turns on when you move it to 'off' position. So something in that off-circuit is not working.
Probably time for some servicing. Be sure that whoever works on it understands Carver's Magnetic Field Coil power supply.
RobertR
UncleMeat
Post by UncleMeat » Tue Feb 20, 2018 11:12 pm
I recall Wayne saying something about the Mag-coils always being on in the M-1.0t, regardless of if the switch is off; and the only way to fully shut it down is to unplug or use a switched 110V like a power strip or sequencer. Is that also true of the M-500t?
briandarflinger
Post by briandarflinger » Thu Feb 22, 2018 9:36 pm
I have several M-500Ts, this is the only one that continues working after switched 'off'
tfm75
Post by tfm75 » Sat Feb 24, 2018 11:52 pm
In 2007 or so Rita from carver corp had to change out my power switch on the rebuild of my M500t for that reason as well
