It is currently Wed May 22, 2013 10:32 pm
Carver HTR-880 troubleshooting
BryanNance
Post Wed Dec 03, 2003 1:54 pm
Howdy,
I have a Carver HTR-880 Home Theater Receiver, and I've had it for several years. I have JBL speakers connected to it, and for the past few months, every time I've turned it on, it comes on for a second with a little bit of hissing in the speakers, and then there's a loud POP and the speakers are silent, and the display on the Carver says "Protect."
I don't have the owner's manual, so does anyone know what the problem might be?
Thanks,
Bryan
please email me at brynagtr@hotmail.com
audioguy1
Post Thu Dec 04, 2003 12:52 pm
If you're lucky it's bad speakers or wire. Un-hook the inputs and outputs and turn it on and see if it will idle. (very important to un-hook the inputs so you don't blow the output transistors by running the amp w/o any load hooked up!!!) If so it's the speakers or speaker wires. If it still goes into protection w/o any inputs or outputs, send it off to the repair shop.
BryanNance
Post Sat Dec 20, 2003 8:26 pm
thanks
I unhooked everything, and it went into Protect mode (which, by the way, the manual says nothing about). Then, I turned it off and on again, and it hasn't said "protect" since.
So, I tried hooking everything up again. I had a vhs player running through the system, and no sound came through the speakers. I turned the volume all the way up on the Carver and heard the very faint sound of audio from the vhs player, and I could hear it no matter what input the receiver was set on. I even tried just connecting one speaker by itself to the Carver, and still no sound.
Weird. Any ideas?
Bryan.
