repair help on M400a amp
williemon
Re: repair help on M400a amp
Post by williemon » Sat Aug 09, 2008 10:32 am
I have tested the primary winding on the field transformer. I removed the green wire from its terminal, then measured between that terminal and the other terminal going on to the fuse holder. thats terminals 1 and 2. I get 1/2 ohm. Is that correct or is it shorted?
Post by BillD » Sat Aug 09, 2008 11:09 am
That sounds good. The primary winding is just a big coil of wire. If you measured from the primary to the secondary and got low Z, I'd be worried.
williemon
Post by williemon » Sat Aug 23, 2008 8:26 pm
Well, the field coil is good I guess, the triac looks good, the couple of outputs I checked read good. Not sure if I want to try anything else. I might just let someone else take care of this for me.
