Carver Reciever 900 left channel very low.
Has anyone had this problem before?
Does anyone have a schematic?
TIA.
It is currently Thu May 23, 2013 3:53 am
Robert R wrote:The question of why the hell someone would remove parts is still to be answered. Sometimes engineering changes are made, after production begins, and parts that are still designated on the board are omitted from the new circuitry. You problem may well lie elsewhere. A look at the soldering points on the bottom side should tell you if there ever were parts in those holes.
I've never seen a 900, but if parts are missing from one channel, there are equivalent parts on the other channel that you can learn from. Look for an R 314 and 313, or maybe 514 and 513. That's how they generally number the other channel. If they are shown there but are missing too, forget about that as a problem. If they are there, they will tell you the original values.
If at all in doubt, best to wait and see if someone comes up with the schematic, or can study another unit for you.
Robert R
