It is currently Wed May 22, 2013 6:06 pm
Need Relay for CT-17 Pre Amp
gsb001
Post Wed Dec 03, 2008 4:52 pm
Hi All,
I'm trying to get my system back up by 12/23.
Based on my post "CT-17 that won't turn off", I think relay RY900 is bad.
Part number:
DMIT - SS - 112LM
Does anyone have or know where I can get this part?
OBI56 checked his sources and came up empty.
Thanks
Steve
Post Wed Dec 03, 2008 4:57 pm
Re: Need Relay for CT-17 Pre Amp
You might not be able to find the exact part. What are the relay specifications — maybe a substitute can be shoehorned in.
Post Wed Dec 03, 2008 10:11 pm
BillD wrote:You might not be able to find the exact part. What are the relay specifications — maybe a substitute can be shoehorned in.
Bill, I got the part number from my very blurry copy of the CT-17 Service Manual and GSB confirmed the number visually. The Service Manual does not list any specs on the relay; in fact, all it says in the description is Relay. If I'm realing the plans and PCB layouts correctly the relay is right next to the switched power outlets.
GSB, any other numbers on the relay (voltage, etc.....) that might give us a clue? Also, some size neasurements would be helpful in pinning down a replacement.
gsb001
Post Thu Dec 04, 2008 4:37 pm
Yes - there are voltage markings. I'll get tonight (at work now) and send with measurments.
Thanks
SB
gsb001
Post Mon Dec 08, 2008 4:53 pm
I tried to get more numbers off this part over the weekend.
Way to small for me to read. I need to get a magnifying glass.
Thanks
Steve
gsb001
Post Mon Feb 23, 2009 9:00 pm
Wanted to update this thread.
I took my CT17 to Midwest Audio in Schaumburg Il.
I got it back about two weeks ago. They were able to repalce the relay with comp part. All is working right now. Repair was about $130 total.
SB
