Re: Repair Help- TFM35
Welcome to the forum david. There should be some others chiming in who have a lot more knowledge on repairs. Did you flip the mono switch while the unit was powered on??
snarffydoggy
It is currently Thu May 23, 2013 5:25 am
davidcountryman wrote:Hi all. I am trying to fix a TFM-35 amp that has a strange problem.
I bought it used and "working".
I played each channel for a little while and concluded that it worked fine. Then, for some reason, when it was idling, I flipped the BRIDGE switch on the back and "BANG". Cap C506 exploded, along with 2 of the 8 output transistors on the right channel. I completed the repair to the output transistors and replaced the cap (6800uF, 35V).
I am using a variac to power up slowly, so the cap is no longer exoloding, but it is still getting too much voltage.
The current story is that there is a white wire that ties the board with the bridge switch and input jacks to the chassis gnd. When that wire is lifted, the voltage across c506 is less than 35V. When it is tied to chassis gnd like it is supposed to be, the voltage on cap C506 goes higher than 35V and BANG.
Why is the voltage on Cap C506 too high? Does anyone have an schematic in PDF?
Thanks,
David Countryman
davidc@bellsouth.net
