It is currently Sun May 19, 2013 9:43 pm
M1.0t Turn on problem.
tpsretard
Post Mon Jan 19, 2009 11:23 am
Hello all. i am glad i found this place.
I have a few carver amps that need some TLC. the main one is my 1.0T and then a M400t
Here i will talk about my 1.0T.
i got it from a friend that had it from new. but he got rid of it because of a problem it developed. it would turn on slow. by this i meen. When you turn on the switch, you could not here the turn on buzz from the MAG Coil. and the 2 leds will turn on with a slow illumination. If you left the amp like this is would eventually turn on. and play wonderfully. the bass is tight and sounds wonderful at high and low volumes.
Now i thought i would ask here as i found u all wonderful carver fanatics like my self.
I am comfortable around electronics, i know enough about carver to know it is no ordinary amp. If i do not get anything back from you all, i will whip out the viriac and short the tric to see if everything lives. but i am prity shore it is the power supply acting up. a mind tells me it might the opto coupler but it is a little bit of a wild guess..
Thanks in advance..
Post Mon Jan 19, 2009 12:04 pm
Re: M1.0t Turn on problem.
Shorting the triac = no more Mag Coil
RichP714 is THE M-1.0t expert.
Post Mon Jan 19, 2009 12:05 pm
DO NOT SHORT THE TRIAC!!!!!
tpsretard
Post Mon Jan 19, 2009 12:07 pm
i know if you short the triac you loose the control over the mag coil. that is what the variac (variable output transformer) is used for, you bring it up with about 25volts ac and you can use that to find critical faults.
Thanks for watching out though..
Post Mon Jan 19, 2009 12:27 pm
Welcome tpsretard
Post Mon Jan 19, 2009 1:03 pm
Send it to RichP714 http://carvermk2.com/ or have him walk you through a troubleshoot. The problem with shorting the triac is that you get full cycle through the field coil. Even with a variac, it doesn't like crossing through zero, which it will do. That field coil is really a very light duty device (not much iron).
tpsretard
Post Mon Jan 19, 2009 1:11 pm
Hi BillD, i have been reading through a lot of stuff here in the last little bit. RichP714 seems to really know a lot on this amp. once i get this repaired i might do some of the upgrades my self :)
I know they do not like to cross through zero. but it will still work, i learnt all but the hard way with an M400, i was given 2 years ago. one was...well...butchered by some one else. so i figured nothing wrong with leaning from it as i could not destroy it anymore.. BOY WAS I WRONG!! But after about 3 months and a lot of patience, it works to this day still all though i am sure it needs a good going over.
i really hope RichP714 or some one else that seems to know a lot about these 1.0ts posts here, i am sure i can do it my self. (i hope that is not famous last words)
I almost wish i could get hold of Bob him self, i know he has vacationed where i live. in Barbados (little island in the Caribbean sea).
Post Mon Jan 19, 2009 4:12 pm
Been to Barbados a couple of times. Stayed at Sandy Lane. Very nice place.
tpsretard
Post Wed Jan 21, 2009 12:34 pm
OK so after getting the M400t running i pulled the 1.0t from storage, and well now it is worst!! even leaving it for a bit it will not turn on at all..
So i opened her up to see what was happening, there is only about 2v AC going into the coil..
my first thought was O GOD, i have fried outputs. so i tested them all nothing wrong with them.
Next i jumped the triac and verified i has 2 working channels. even with a current limited variac this amp sounds wonderful at low volumes...
So my problem is just the power supply it would seem
I am hoping to get some input from RichP71 as he seems to be the guru with the 1.0t's on this forum..
PLEASE help me out :)
Post Tue Jan 27, 2009 8:11 am
*bump*
birdyman
Post Tue May 12, 2009 10:19 pm
tpsretard wrote:Hello all. i am glad i found this place.
Because your amp turns on eventually, there are not thing wrong in triac and opto coupler unit. You need to think about possibilities of some thing is driving optocoupler too hard when unit is cold. You need to check regulator IC 301 and faulty op amp ic 101. First of all disconnect gain stage op amp MC101, MC102, Mc103 and see if your amp comes on right away as you trun it on. If it does, check for gain stage. If it does not, suspect IC301. Do not short triac that can easly compound problem by not having any protection.
Good luck
