Amp won't turn off
stevewithrow
Re: Amp won't turn off
Post by stevewithrow » Fri Jan 23, 2009 5:35 pm
Give these fine folks a call
viewtopic.php?f=4&t=7093
Post by F1nut » Fri Jan 23, 2009 7:18 pm
Pull plug.
Post by BillD » Fri Jan 23, 2009 8:05 pm
Not a lot of information here, is there :D My guess is that it could be a switch problem :lol:
Post by F1nut » Fri Jan 23, 2009 8:14 pm
Fix switch.
Post by treitz3 » Fri Jan 23, 2009 8:25 pm
Keep on.
stevewithrow
Post by stevewithrow » Sat Jan 24, 2009 12:31 am
stevewithrow wrote:Give these fine folks a call
one more time.....
Rainman
Post by Rainman » Sat Jan 24, 2009 6:32 am
F1nut wrote:Pull plug.
F1, for the first time I think I can help you make one even shorter... instead of "Pull Plug" how about this: "Unplug." :D :D :D Suddenly I am flashing back to your all time funniest "NO" reply to the home theater question... :lol: :lol:
Like Bill and F1 both stated, it almost certainly has to be a problem in the switch. Depending on how handy you are with switches and things it should not be too difficult to determine if it's just stuck and can be freed up by cleaning with a shot of switch cleaner etc. or if the switch will need to be replaced. :-k 8)
Rainman
Post by F1nut » Sat Jan 24, 2009 8:05 pm
Thanks. Short enough? :D
Post by kingman » Thu Feb 19, 2009 7:47 pm
How many times can you PULL THAT PLUG!!! That's not what that man needs!!! He needs HELP!
