wkathol wrote:Everything is all good .. Just thought I'd let you guys all know. I still don't have a clue what happened. I unplugged the amp from the monster power center and plugged it just straight into the wall. Turned it on and everything seemed ok. Plugged it back into the power center and it all worked just fine.
IMO, would still be very cautious, if I understand correctly, #1 origional plug in ok, #2 made equipment move, replug in bang, blew o/c device #3 unplugged (reset) moved and checked out, pushed in, tried amp in another socket first, ok, now in monster centre, seems ok????
My guess, "hairs" for fault condition most likely present, causing (#2) result , "
blew condition clear, while taking out o/c device".
If that were the case, the fault area will be "ionised" carboned and slight movement again could result in a second "bang" and blow o/c device a second time, this then
"could result in serious damage this time"Got lucky the first time around.
If it were me, I would power down all, move everything out again and do a second serious thorough check, look for evidence of ionising, or fault creating circumstances....
tough call! I would be scared to move
"anything" while being powered up! (cleaning, vacuming etc.)
..to give u some indication what is at play when these o/c devices blow (tripping)
standard 15 amp residential breakers are rated for max. instantaneous short time over current of 10,000 amps , (that is... ten thousand amps.)
The proceedure I would use is:
In daylight, #1 turn "off" all equipment power switches #2 turn "off" panel circit breaker feeding your stereo equipment, then #3 remove all powercords (stereo equipment) pluged into wall sockets after doing this u may turn "on" panel circuit breaker if it feeds other room devices (lamps etc.) #4 do your examinations, move equip etc. when u are satisfied, replace all equipment
#5 turn "off" circuit breaker again at panel, now return and "plug in" your stereo power cords, "to wall sockets" #6 turn "on" circuit breaker at the house panel, feeding your stereo wall sockets. Lastely, turn "on" individual equipment power switches at stereo centre.
...hope this helps!
In short: (with respect to your stereo system)
Until u are absolutely satisfied there is no risc of possible fault (short circuit) conditions
I would not move any equipment, un plug or plug in any power cords anywhere, including the power cords to the wall sockets,
while the wall sockets are in the energised state.
country's...pure sole...
