CT-24 output problems
Post by beemers417 » Sun Feb 15, 2009 9:41 am
I have a CT-24 that has low gain through all the sources except the tuner. Any help on this matter would be appreciated. I am also looking for a schematic for this model.
Re: CT-24 output problems
Post by thuffman03 » Tue Feb 24, 2009 2:51 pm
Can't help you Tom since you know more than I do but this will bump the post back up and hope someone has an idea.
Post by beemers417 » Tue Feb 24, 2009 5:45 pm
Thanks T
gdb
Post by gdb » Tue Feb 24, 2009 5:48 pm
Click link for schematic/manual. Have you tried checking your IC cables and also, operate ALL of the buttons/knobs repeatedly and vigorously, hey, sometimes it works !! You could try spraying DeOxit in the pots and RCA terminals before trying a different set of ICs too!
Good luck !!! :)
http://www.vintageaudiomanuals.com/-C-.htm
Post by beemers417 » Tue Feb 24, 2009 8:03 pm
Thanks for the info gdb.
falcon377
Post by falcon377 » Thu Feb 26, 2009 8:37 pm
I have a working ct-24 I will trade you for a TUBED pre-amp.
Post by beemers417 » Thu Feb 26, 2009 10:25 pm
That would give me 1 1/2 CT-24's. If you throw in a TFM-35, you have a deal. :-k
