It is currently Thu May 23, 2013 10:33 pm
CT-24 output problems
• Page 1 of 1
I have a CT-24 that has low gain through all the sources except the tuner. Any help on this matter would be appreciated. I am also looking for a schematic for this model.
Re: CT-24 output problems
Can't help you Tom since you know more than I do but this will bump the post back up and hope someone has an idea.
Click link for schematic/manual. Have you tried checking your IC cables and also, operate ALL of the buttons/knobs repeatedly and vigorously, hey, sometimes it works !! You could try spraying DeOxit in the pots and RCA terminals before trying a different set of ICs too!
Good luck !!!
http://www.vintageaudiomanuals.com/-C-.htm
Good luck !!!
I have a working ct-24 I will trade you for a TUBED pre-amp.
That would give me 1 1/2 CT-24's. If you throw in a TFM-35, you have a deal.
• Page 1 of 1
