CT-17 pre-out help
diz131
CT-17 pre-out help
Post by diz131 » Mon Feb 16, 2009 1:59 am
Hi all, I have come across a CT-17 preamp and a AV-64 Amp and I'm having some difficulty hooking the two up but that may be user error :(. Using the remote amp output from the CT-17 everything works fine but when I try using the CT-17 Pre-outs to the AV-64 I get nothing. Are my pre-outs bad? or are they supposed to be connected to a Sub? Unfortunately I do not have a Sub to test them with. Any help with setting these two up would be great! Thanks!
Rainman
Re: CT-17 pre-out help
Post by Rainman » Mon Feb 16, 2009 2:14 am
I think the first thing everyone will want to know is do you have an owners manual for your CT-17 because this will likely determine the best, easiest, way to help you sort it out... :-k
Rainman
diz131
Post by diz131 » Mon Feb 16, 2009 2:34 am
Unfortunately I do not have any of the owners manuals for either unit, I figured if the remote out can connect to the AV-64 then the pre-out should work too.
Rainman
Post by Rainman » Mon Feb 16, 2009 3:09 am
I am not familiar with the back of the CT-17, but I can tell you there are several Carver units that the inputs and outputs can be made to go to different places like external processors (eq's) by simply removing or installing some of the little U shaped jumpers you will notice on the back of your unit. This would be most likely on some units, but without knowing the back of your unit I will say it is a possibility. The only other thing I can think of is to make sure that there is not some weird feature on or button pushed that might affect your pre-outs, and also make sure that the multi room feature isn't some how affecting things due to a failure or something that might be just plain bizarre.
Without having an owners manual or one to look at in person that is about as far as I am able to travel at this point. This is where the others will usually chime in and pick up the slack. [-o<
If you need any further help let me know and I can do a little "rootin and goughing" like at Bristol or try a call or two for you... 8)
Rainman
Post by OBI56 » Mon Feb 16, 2009 4:49 am
Did you remove the U plugs from the External Processor Loop jacks on the back of the unit? If so, then it will never play through the Main Out jacks.
CT-17 back.JPG (34.82 KiB) Viewed 952 times
CT-17 ExtProLoop.JPG (35.44 KiB) Viewed 952 times
diz131
Post by diz131 » Mon Feb 16, 2009 11:19 am
Ah ok, I dont have any U plugs so that may be why I cannot connect the Av-64 through that output. Any idea where I may be able to find these U plugs, are they availible at most places? I'm not too familiar with what they look like, Thanks for the help so far!
Post by TNRabbit » Mon Feb 16, 2009 12:07 pm
Radio Shack should have them...
Post by OBI56 » Mon Feb 16, 2009 2:24 pm
diz131 wrote:Ah ok, I dont have any U plugs so that may be why I cannot connect the Av-64 through that output. Any idea where I may be able to find these U plugs, are they availible at most places? I'm not too familiar with what they look like, Thanks for the help so far!
They are basically solid wire jumpers that are U shaped that bridge from out to in. In a pinch, you can use short RCA to RCA cables to do the same thing. They do vary in spacing, so you need to measure them centre ot centre to make sure you get the correct size.
Here are some fancy ones that do not need to be measured
http://www.needledoctor.com/Audioquest- ... tegory=427
These are MUCH cheaper as long as they fit your preamp
http://www.futurlec.com/RCA-Jumper.shtml
diz131
Post by diz131 » Mon Feb 16, 2009 2:40 pm
I tried radioshack but no luck, I'm going to try with some of my RCA cables to see if it works and then I will order some shorter ones, Thanks for all the help!!!
Post by frankieD » Mon Feb 16, 2009 4:30 pm
I got in on this late but you guys sure covered it well.
The proc loop must be jumpered in order for the pre-outs to work.
Any RCA cables will do so you should have the pre-outs working by now.
I wouldn't sweat the jumpers, you will find some eventually, meanwhile enjoy the gear.
FrankieD
diz131
Post by diz131 » Mon Feb 16, 2009 5:51 pm
Ok so I used some RCA's to turn off the "Ext. Proc" out and then tried hooking up the pre-out to the AV-64 main input but still no sound, I think my pre-out connection may be shot because the Remote-Out option works, weird.
Post by BillD » Mon Feb 16, 2009 6:50 pm
You did connect the RCAs from the out to the in, yes/no?
Post by OBI56 » Mon Feb 16, 2009 7:36 pm
diz131 wrote:Ok so I used some RCA's to turn off the "Ext. Proc" out and then tried hooking up the pre-out to the AV-64 main input but still no sound, I think my pre-out connection may be shot because the Remote-Out option works, weird.
Just an idea here. Last button on the left on the second row called Engage. Is it on or off?
diz131
Post by diz131 » Mon Feb 16, 2009 7:42 pm
hmmm good question, let me check.
Post by TNRabbit » Mon Feb 16, 2009 8:02 pm
BillD wrote:You did connect the RCAs from the out to the in, yes/no?
Bill, I think you and I are thinking the same thing....
Do you have a pic of the back of your preamp & connections, diz131?
