It is currently Thu May 23, 2013 9:58 am
TFM-45 Oscillates at full power w/ no input
kellman
Post Tue Mar 31, 2009 11:11 pm
Hi, I recently acquired a TFM-45 from a friend who said one channel was not working.
With no input, and power applied, both channels ping their meters, and there is a loud hum from the transformer. When I say ping the meters - the meters go full scale and back to zero or 1/2 and back up, and so on and so on. Looks like oscillation.
Is there something obvious to check or will this take a major effort to fix? service manual anywhere? I am an ex- EE and can probe everything, can bring it up with a variac, can take some oscilloscope screens if you would like.
I tried it with inputs grounded, same thing as with open circ.
I then tried it with a signal on the inputs at very very low volume, same result.
all this with no load on speaker terminals.
Advice?
Post Tue Mar 31, 2009 11:39 pm
Re: TFM-45 Oscillates at full power w/ no input
Could be the damping adjustment is way off. I know I got a loud hum when I adj mine s.t. the output volts at speaker terminals with 8 ohm load was way above spec value of 1.0 volts. It drifts (if "drift fix" service bulletin fix not done. I did this to my 45 and it no drift no mo!).
Go to the "other site" (www.thecarversite.com) to get an easy download of the 45's service manual. Can find specific instructions for all this on a TFM-45 related thread here (including instructions on how to download the "virtual testbench" signal generator required to do the damping adjustment). Search my posts (elgrau) for TFM-45 key word. Do the three adjustments spelled out there and see if problem goes away. If not then probably time for a $179 "refurb" trip to "Bob's place" in Washington state!
kellman
Post Wed Apr 01, 2009 12:17 am
Thanks.
1. I could not find your thread? But I did get the service manual- thanks. 95 pages... wow....
2. I don't need "virtual" test bench. I have a tek signal generator, can input any signal into this baby that I need.
3. what 3 adjustments are you talking about?
4. don't answer right away, I will keep looking for your thread......
Post Wed Apr 01, 2009 12:26 am
Welcome to the forum. You picked up a great amp.
+1 to send off to Bob and Rita. With the age of the amp it might have several things that need attention and when you get it back it will be as good as the day it was born.
Post Wed Apr 01, 2009 12:38 am
kellman
Post Wed Apr 01, 2009 10:41 am
Thanks, I found that thread myself but did not know if it was the right one. Will give it a shot in the next few days...
