It is currently Fri May 24, 2013 4:20 pm
New foam for ALS-III's?
abarson
Post Mon Dec 22, 2003 5:12 pm
My ALS-III's are looking shabby, as the foam covering the tweeters (running the whole length of the speaker, actually) has deteriorated to the point of crumbling onto the floor on its own.
Can anyone recommend some place where I can get some replacement material?
Jagman
Post Thu Jan 29, 2004 10:54 pm
Hi- I'm not sure what the foam is you are talking about that runs the length of the tweeters. I believe you are speaking about the ribbons, there is no foam that I know of in the material used to make the ribbons, maybe the kapton is deteriorating, I guess. take another look. Do the speakers produce any sound?
Post Fri Jan 30, 2004 12:16 am
Jagman,
He's talking about the ALS III's not the Amazing's. The ALS III's ribbon has a piece of foam over the front running from top to bottom and between the oak panels.
I believe he posted this elsewhere on the forum and received the answer to his question.
F1
Jagman
Post Fri Jan 30, 2004 1:41 am
Ah, got it- thanks for the correction.
