C-1000 Sound Level Problem
I noticed more sound coming from the right front channel than the left front channel. I entered into the TEST TONE's menu and found that when the left front channel is selected I get a signal from both the front left and the front right channels. When I select the right front channel I get a signal from only the right front channel, as I should.
Can you tell me what maybe the cause?
This is very similar to a problem I experienced when I first purchased the amplifier except it was an issue with the left rear channel sound level. The local certified Technician quickly repaired this problem but unfortunately the Technician spoke little english so I am not sure what was repaired. I think he said it was a problem with the volume control?!?
Thanks again.
Dick
Thanks again.
Dick
