m4.0t
Amplifier Reviews
carversound
m4.0t
Post by carversound » Mon Jan 07, 2008 7:02 pm
specs. please
Kahuna
Location: Area 51-Skunk Works Division - Space Age Materials Lab
Post by Kahuna » Mon Jan 07, 2008 8:27 pm
Continuous Average Output Power
Both channels driven 375 WPC into 8 ohms from 20Hz to 20 kHz
500 WPC into 4 ohms from 20Hz to 20 kHz
Bridged-mono operation 1000 WPC into 8 ohms from 20Hz to 20 kHz
Power at clipping 475 WPC into 8 ohms 1 kHz
Dynamic Headroom 1.5dB @ 8 Ohms
1.75dB @ 4 Ohms
Frequency Response 20Hz to 20 kHz +/- 0.5dB
T.H.D. Less than 0.5%
IM Distortion Less than 0.15%
Noise -110 dB A-weighted, referenced to rated power
-84.3 dB A-weighted, referenced to 1 watt
Input Impedance 115k Ohms
Sensitivity 1.7V rms for rated power into 8 ohms
Gain 29.5 dB
Excellent amp! (I own one). ;)
"The only thing in this world that gives orders, is balls"
German engineering in the haus..........Jah!
I'm from the United States of KISS MY @$$
Handle every stressful situation like a dog: Piss on it and walk away..
74bronco
Post by 74bronco » Tue Jan 15, 2008 2:00 am
funny I was told by a tech that the 1.0t and 4.0t are very similiar and use the same output transistors and the same number of them!!
voltage squared divided by ohms=watts
Yamaha vsx 661(7)m1.0t(1)m1.5t(1)m200t deceased(2)m400a's(1)tfm24,ct-7,pt2400 doing sub duty,original amazings
74bronco
Post by 74bronco » Tue Jan 15, 2008 2:03 am
just needed to add that their mono bridged rating is the same but the 1.ot is rated at 200rms continuous 400 peak i.e 3db headroom at 8 ohms.
Post by treitz3 » Wed Apr 02, 2008 5:48 pm
The M4.0t has the best top end of any Carver gear I have owned. Sweet roll off, very natural reproduction and smooth mids. The lower end of the frequency spectrum is ample, but lacking in terms of "slam". Not a omission of bass, but not a heavy hitter when it comes to bass output. It is very tube-like sound. Compared to a M1.0t, the differences are quite different, regardless of similarities of components and design.
RichP714
Re:
Post by RichP714 » Sat Apr 12, 2008 9:24 pm
74bronco wrote:funny I was told by a tech that the 1.0t and 4.0t are very similiar and use the same output transistors and the same number of them!!
They use the same output transistors, yes, but that's probably more a result of the high tier rail voltages being similar than anything else. The rest of the topology is similar on the macro scale, it's a push-pull input, a bootstrap current source, a three tier ladder type class G.
Differences are in the feedback (t-mod) circuit, the bootstrap current source of the M-4.0 is more stout, the drivers are paralleled just before the high tier output.
Not ever having heard an M-4.0t, it looks like it could source a bit more current than the M-1.0t, which may result in tighter bass control...the freq response curve also has a slight rise near 10Khz.
Re: m4.0t
Post by Mr. M-500t » Sat Apr 12, 2008 9:34 pm
This is the review area not the discussion area guys ???????????? #-o :-k
Return to “Amplifiers”
