Theme default change, and Avitar resizing
Upcoming changes to be made to the forum
Post by Toy Maker » Tue Sep 08, 2009 8:15 am
I am changing the "Default" theme for the forum to DVGFX) ((There is a reason for it... you'll see why later))
I would advise using it for a while and try to get used to it.
For just this week, I am making this theme the ONLY one available (DVGFX). At the end of the week I will re-set the forum so you are able to change the theme to whatever you like. At the end of the week you will still able to go into your UCP and change the theme back to the previous theme "prosilver2" if you like.
But I would really advise using this one, for a little while, and try to get used to it .
I am also going to reset the Avitar size MAX to 200 x 200. Some are getting a little out of hand size wise.
If your avitar is larger than 200 x 200, please go into your UCP and resize it, very easy, just do the math, and rescale the image. The forum will automaticly resize it if you type in the correct numbers
Re: Theme default change, and Avitar resizing
Post by Toy Maker » Tue Sep 08, 2009 8:22 am
Also... if the background looks "black" your screen settings are off. It is a dark gray, but if it looks BLACK to you, you may want to try adjusting your screen, brightness and or contrast a little.
With my laptop, if I tilt the screen I get different shades of gray, same with my LCDs at the office. Just a little FYI
Post by TNRabbit » Tue Sep 08, 2009 9:04 am
Where the hell is the "View New Posts" button???
Post by Toy Maker » Tue Sep 08, 2009 9:25 am
Board Index, top left
Post by BillD » Tue Sep 08, 2009 11:23 am
Well, the borders are black, and the insets are very dark grey. Buttons are shaded grey to black. But the grey is very dark.
Post by Toy Maker » Tue Sep 08, 2009 12:15 pm
I'm liking this one a little better... This one I can customize the colors myself, and make 20 different versions of the same theme based on what colors everyone would like to see...
Post by Mr. M-500t » Wed Sep 09, 2009 7:06 am
It's very hard to make things out James ! :-({|=
dok
Post by dok » Thu Sep 10, 2009 10:31 pm
Wooo Hooo Back to the original! Thanks. =D> =D> \:D/
Post by engtaz » Fri Sep 11, 2009 7:10 am
The last change messed up my logging in ( keep giving me errors, I found out by logging out and having no problems and i had the old theme there with me logged off) untill I had to go to Control panel and chose a theme.
edriz
Post by edriz » Fri Sep 11, 2009 10:25 am
I don't see any difference??
Currently In Use
Current Rack; Carver M-4.0t Power Amp, Carver C-4000t Pre Amp,Empire 598III Turntable, Denon DL-103R cart/stylus,Pioneer RT-909 Reel To Reel,Nakamichi Dragon cassette deck,DBX Pro Series 231 Dual Channel 31 band EQ,Pioneer PDR-555RW CD,DBX-3bx,Berwun Research 7000A TNE,DBX-224x DS TypeII NR, Klipsch Lascalas "Loud,Proud,Clean & Mean"
Post by treitz3 » Fri Sep 11, 2009 12:19 pm
He changed it back to the original Ed. You can go into the user control panel and change it to whatever one you would like to use. Cool eh?
tomstat
Post by tomstat » Fri Sep 11, 2009 9:22 pm
Very cool... I like the original, but also that folks have a choice to use other themes.
Wardsweb
Post by Wardsweb » Thu Nov 12, 2009 3:45 pm
When I'm not logged in, there is a gallery link. When I log in, it is gone. Am I missing something?
~There are many roads to audio nirvana. While the ultimate goal may be the destination, don't forget to enjoy the ride.~
Return to “(( Site & Forum Updates ))”
