It is currently Mon May 20, 2013 3:44 pm
Hello from Michigan! And a Question... With Picture!
brianjcollins
Post Sat Jan 02, 2010 9:17 pm
Hello All,
I have an M1.5t and a C-1 hooked up to some Bose 901's Series V, and also have a question...
With my amp sitting close by a mac mini and ps3 could I damage the hard drive? There is only about 1/2" of oak between the amp and mac. Someone had said it could damage discs and what not, im sure how that is technically possible with cd's as they are 'burned' bumps. I don't see it erasing physical markings, but for other types of media that are magnentic...
Thanks!
Post Sat Jan 02, 2010 9:50 pm
Re: Hello from Michigan! And a Question... With Picture!
Well you could get magnetic radiation from the transformer. Remember, your hard disks are magnetic. That said, your computer has a power supply in it that doesn't erase your hard disks, which are normally positioned right below it. If you cases are metal, I think you'll be fine.
brianjcollins
Post Sat Jan 02, 2010 9:59 pm
Ah, very valid point. I'm sure the hard drive itself has enough shielding, as they make 1200watt PSU's..
Thanks for your response.
Rainman
Post Sun Jan 03, 2010 2:43 am
Where in Michigan are you? We are in Kzo where it never stops snowing!
As mentioned I would think the metal from your component chassis should be sufficient, but if it's not and the flux capacitor fails you will be the first to notice :D I would be more worried about the Bose speakers doing damage to your music than the other issue :lol: :lol:
(Sorry, I just had to say it)...... #-o
Rainman
Post Sun Jan 03, 2010 4:35 am
Welcome
stereo_buff
Post Sun Jan 03, 2010 4:47 pm
BillD wrote:Well you could get magnetic radiation from the transformer. Remember, your hard disks are magnetic. That said, your computer has a power supply in it that doesn't erase your hard disks, which are normally positioned right below it. If you cases are metal, I think you'll be fine.
The power supply in the computer may be shielded with mu metal to ensure the hard drive isn't affected...
Post Sun Jan 03, 2010 4:59 pm
Well, I've taken apart a fair share of PC power supplies, and they're boxed in either aluminum or zinc alloy.
Post Sun Jan 03, 2010 6:34 pm
Welcome to the forum brianjcollins! Very clean set-up! Thanks for the picture!
Post Sun Jan 03, 2010 10:03 pm
Welcome to the forum. Nice set up brianjcollins! =D> =D> =D>
Breaking Glass
Post Sun Jan 03, 2010 10:18 pm
Welcome to the forum. How do the 901’s sound set up like that?
brianjcollins
Post Fri Jan 08, 2010 11:55 am
Well, they sound pretty good. Honestly my sources arn't optimal with the mini-mac audio and hardly any of my music is lossless. I don't complain though, seem clear but they should be out from the wall a bit further.
I've played around with the position a bit, but I still have to make the wife happy with it's appereance. It's a balance.
I live in southeastern michigan, more specifically Ortonville/Brandon.
Post Fri Jan 08, 2010 12:38 pm
Slooooowly move them forward, maybe 1" a week. :D
gdb
Post Fri Jan 08, 2010 12:59 pm
Welcome! I was born in Washtenaw County, Mich........about a hundred years ago!! :shock: :lol:
Post Fri Jan 08, 2010 1:18 pm
Weren't we all. I was born in Detroit at Henry Ford Hospital in 1948. How do you say Baby Boomer.
gdb
Post Fri Jan 08, 2010 1:24 pm
All of my female relatives/ancestors worked at Willow Run and the other WWII factories , I wasn't "squeezed out" until 1952 :)
Return to "The Welcome Mat"
