It is currently Wed May 22, 2013 1:06 pm
Newbie here
Blazer406
Post Sat Feb 13, 2010 2:58 pm
Newbie here
I got a simple system... kinda dated..... around 10 years old.......
I have:
Denon AVR 3300 Integrated receiver - 5 x 105 if I remember correctly
Toshiba SD 6200 DVD Player
Energy C8's for the main speakers
Energy C2's for the surrounds
Energy AC300-1 center channel
Sunfire True Subwoofer Signature
I need to find a reasonable place to service my sub. It is an awesome piece. I have used it very little however in the past 6-8 years since moving to my new house. Before I moved, the sub developed a low freq hum if it was plugged into the wall..... regardless if any music signal was going to it or not. I tried different outlets... different circuits..... etc...... once I moved... I didn't set up a home theater very quickly..... but did hook it up... to listen to music.... still had hum....
Well, I got my first high def flat screen TV and blue ray player for Christmas and have plans to hook it all back up. I would like to get my sub serviced to fix this hum. It is barely audible with anything playing... but turn everything off.... and it just sits in the corner and hums until you unplug it.....
Any suggestions?
I tried calling the Rita Helm number I found on another site.... apparently that number isn't connected anymore.
Thanks.
Post Sat Feb 13, 2010 3:14 pm
Re: Newbie here
Welcome to the fourm! and you found the right place. Try contacting Rita through the web site:
http://www.ritasvintageaudio.net/
Blazer406
Post Sat Feb 13, 2010 3:43 pm
Re: Newbie here
Jag_97470 wrote:Welcome to the fourm! and you found the right place. Try contacting Rita through the web site:
Thanks for the quick response. I have contaced Bob thru email using the website you gave me. It is unclear to me on their "rates" to fix my sub..... so I emailed him the particulars.... maybe I'll get a response early next week.
Again.... thanks for the info.
Post Sat Feb 13, 2010 4:40 pm
Re: Newbie here
Welcome to the forum!
Post Sat Feb 13, 2010 4:48 pm
Re: Newbie here
Try a couple of things with your sub. First, tighten all the washers on the potentiometers. They need to make good contact of your sub will hum. Second, ground bust the sub (you know, those three prong to two prong thingys). Try plugging your sub in both ways after going to two prongs.
Post Sat Feb 13, 2010 8:23 pm
Re: Newbie here
Welcome to the forum!!! =D> =D> =D>
Post Sat Feb 13, 2010 8:40 pm
Re: Newbie here
Welcome
Post Sun Feb 14, 2010 5:20 pm
Re: Newbie here
Welcome aboard
Federico
Post Sun Mar 07, 2010 7:24 pm
Re: Newbie here
welcome to the forum.
peck555
Post Mon Mar 08, 2010 12:39 pm
Re: Newbie here
Howdey, and welcome to the forum.
Post Mon Mar 08, 2010 1:04 pm
Re: Newbie here
WELCOME~
Alistair
Post Wed Mar 10, 2010 2:11 pm
Re: Newbie here
hi welcome to the forum.
Post Wed Mar 10, 2010 8:59 pm
Re: Newbie here
WELCOME, This is the coolest Place around 8)
Return to "The Welcome Mat"
