New Member Says Hello
Re: New Member Says Hello
Post by Jag_97470 » Fri Feb 26, 2010 10:53 pm
You are correct, there is not much out there on the web for this model. Do you know what year it is? Something is telling me Phoenix Gold sold this under the Carver Digital name, but I could be wrong. Maybe the old timers will chime in and clarify for you.
Post by beemers417 » Sat Feb 27, 2010 12:39 am
Welcome!!! You came to the right place. \:D/
Post by engtaz » Sat Feb 27, 2010 5:52 am
Welcome
Post by Toy Maker » Sat Feb 27, 2010 8:55 am
Jag_97470 wrote:You are correct, there is not much out there on the web for this model. Do you know what year it is? Something is telling me Phoenix Gold sold this under the Carver Digital name, but I could be wrong. Maybe the old timers will chime in and clarify for you.
Welcome to the forum !! Stick around, we'll really get you hooked !!! :lol:
The PM-200 looks to be an ORIGINAL Carver built amp... not PG built.
Here is the owners manual for the amp: http://www.carveraudio.com/manuals/pm-200-OM.pdf
You can see on the 2nd page it says:
"MODEL PM-200
Low Feedback/High Headroom Magnetic-Field Power Amplifier
OWNER’S MANUAL
IMPORTANT NOTICE
Please read carefully!
This amplifier was originally manufactured by Carver Corporation. There are
references contained within this manual to addresses and telephone numbers
that should no longer be used to obtain technical support or factory service.
For any assistance with this product please contact:
Carver Professional
A Division of Phoenix Gold International, Inc.
9300 North Decatur
Portland, Oregon 97203
ZeroG
Post by ZeroG » Sat Feb 27, 2010 10:44 am
Edited
ZeroG
Post by ZeroG » Sat Feb 27, 2010 10:48 am
Thanks for the welcome. Also the manual - it really helps. There was one online that was incomplete and pretty useless.
Would anyone have a schematic or parts list available? I'm thinking of recapping it, due to age, if I can get reasonably priced screw terminal caps. Otherwise I might use it for a sub amp or a PA amp. If I can recap it, it might make a good 2 channel amp.
Breaking Glass
Post by Breaking Glass » Sat Feb 27, 2010 10:56 am
Welcome!.
Post by Jag_97470 » Sat Feb 27, 2010 10:58 pm
"MODEL PM-200
OWNER’S MANUAL
IMPORTANT NOTICE
Carver Professional
9300 North Decatur
That is very interesting James, maybe that is why I could not find much on this model. Even AudioGon did not list it and now I see why. It says this amp is a commercial grade amp and the main purpose is for running a PA system or connect to a mixing console or where instruments may be used. I don't know if using this amp sticky for a conventional 2-channel set-up may not be the use this amp was designed for? :-k
Alistair
Post by Alistair » Wed Mar 10, 2010 1:10 pm
hi welcome to the forum.
Return to “"The Welcome Mat"”
