It is currently Sat May 18, 2013 6:51 pm
Carver SD/A 360 multiCD questions
Post Sun Mar 21, 2010 3:05 pm
Re: Carver SD/A 360 multiCD questions
Pop the top again remove the CENTER screw that holds the disc assembly across the platter (it's right in the middle of the platter) and raise it up. You can access the laser lens from there--just clean it with a q-tip & some pure alcohol (windex will do in a pinch, just make sure you get it cleaned off dry with no smudges. Then re-assemble. This will cure 90% of reading errors. If you have further trouble, give me a call (PM sent) & I'll talk you through a couple other things you can do.
Post Sun Mar 21, 2010 3:18 pm
Welcome to the forum!
Post Wed Mar 24, 2010 7:51 am
Also, Robert...you WILL be assimilated~
Post Wed Mar 24, 2010 9:17 am
Welcome
Return to "The Welcome Mat"
