It is currently Thu May 23, 2013 12:27 pm
Nebie, needs help
Post Tue Mar 23, 2010 11:17 pm
Re: Nebie, needs help
Welcome to the forum!!
Someone here will most likely be able to help you out
Post Tue Mar 23, 2010 11:34 pm
Welcome as you might be the only guy here with a system similar to mine.
The best thing would be to save up and search ebay for some better used crap.
I advise against that as it will soon consume your life.
Post Wed Mar 24, 2010 12:16 am
My experience(s) with The Receiver is that the "soldering job" not all that great and it pretty easy to have a broken (or totally missed!) joint somewhere on one of the boards. Pull the top and while it "running" tap around (I use the eraser end of a wooden pencil) the boards until/if you find a spot on one of the boards that makes the right channel go in and out...shut it off and carefully inspect (with a magnifying glass/light if possible) all around that area for a "bad" joint. if found (or even "suspect") re-heat/re-solder that joint. this might actually work! Also, contact clean all the volumn and balance pots....
Post Wed Mar 24, 2010 7:50 am
Welcome, picky~
You WILL be assimilated...
Post Wed Mar 24, 2010 8:32 am
WELCOME TO THE FORUM!!! =D> =D> =D>
Post Wed Mar 24, 2010 9:17 am
Welcome
Return to "The Welcome Mat"
