New Member, new to Carver
TongueArt
Post by TongueArt » Wed Feb 22, 2006 3:13 am
Dear All,
I bought a Carver Magnetic Field Amplifier which I think is a receiver and eager to use it. When I power up a light illuminates showing "locked." My question is how do I unlock the receiver so I can use it?
Thanks greatly,
Leonard
Post by F1nut » Wed Feb 22, 2006 4:35 am
Welcome to the forum.
Amps and receivers are two different animals. What is the model number?
"Locked" usually means the protection (safety device) is engaged, not a good thing.
TongueArt
Post by TongueArt » Wed Feb 22, 2006 1:51 pm
On eBay this Item number: 5869684856 is what it looks like. There is no model number on it? It is called on the front a "Magnetic Field Power Amplifier" Although it seems to be a receiver with functions PHONO, VIDEO/DAD, AUX, FM, AM.
Thanks for replying, any suggestions. If it is locked how do you go about entering a code to unlock it? What is the entry sequence?
Leonard [/url]
Post by F1nut » Wed Feb 22, 2006 2:19 pm
That is a receiver and the model is called, The Receiver.
After looking at one close up, it appears the "locked" light is for the radio station signal.....to tell you the station is locked in. If the unit doesn't play, then that's something else.
TongueArt
Thanks
Post by TongueArt » Wed Feb 22, 2006 5:09 pm
Thanks for replying. I falsely assumed it was a security code preventing access to the receiver. I bought a BMW car radio that required a security code to use it. If you did not know the code you were... out of luck. I guess I will find a repair place.
Leonard
Post by F1nut » Wed Feb 22, 2006 5:42 pm
Just so you know, the retail value of your unit is about $200.00 in mint condition.
George
Post by George » Wed Feb 22, 2006 7:21 pm
Your receiver should have "jumpers" on the back, connecting the "Pre-Out" and "Main-In" jacks. If those jumpers are not there (they look like metal "U"s), a pair of regular RCA cables will work just fine. Without the jumpers or a pair of cables that thing won't make a sound.
Return to “"The Welcome Mat"”
