It is currently Thu May 23, 2013 12:49 am
Newbie looking for advice
• Page 1 of 2 • 1, 2
Hi just joined and looking for advice. I don't own any Carver equipment as of yet but I'm looking to buy an AV806X from Ebay. I would be useing it in a home theater system that I use mostly for music listening of CDs and multi channel music SACD and DVD audio. My present system is an Integra DTR 6.3 receiver. I use the pre amp outs for the fronts with a Y cord to 4 channels of a Harmon Kardon PA5800 to 2 amp bi wire a pair of JBL L7 speakers for my front and use 5th chanel to power a CL505 center. The Integra powers the rear surrounds which are a pair of JBL L5. All speakers are 6 ohms except the center. I'm pleased with the performance of the HK amp but the built in amp of the Integra is very poor at best for driving 6 ohm speakers. I would like to buy the Carver and use 4 of the channels to drive the L7's and 2 channels to drive the L5's. The L5's aren't bi wire or bi amp capable. The Integra is fine driving 8 ohm speakers. I would use this to drive the CL505 and an SC305 for front center and rear surround respectively. This is probably a stupid question but would the Carver have any trouble driving the 6 channels of 6 ohm loads that I would be asking it to do? I'm pretty sure it would. I can't find any info on this amp anywhere except that it is 133 wpc at 8 ohms. I think I saw somewhere that it can drive 6 4 ohm loads but I'm not sure. Is this amp rated at all channels driven? I always wanted to own a Carver and I think this is the time.
Re: Newbie looking for advice
Welcome to the forum.
I have never seen any info on 4 ohm loads on the 806. That being said I would have to say that that amp should have no issues with a 4 ohm load into 6 channels. I could not see Bob Carver design a amp that would not be able to drive that.
Welcome
Hi and welcome to the forum. I'm not familiar with the AV806X, but I think most Carver amps can handle 4-8 ohm speakers with no problem. I'm sure someone will chime in soon with an answer for you.
Welcome. PM sent as it relates to question.
You may be able to glean some info out of these reviews of it !
http://www.audioreview.com/cat/amplific ... 83crx.aspx
Welcome to the dark side !
Welcome!!!
Just the fact that it's bridgable indicates that it's atleast 4 ohm stable.Sunfire TGP-III, 200x5, Signature Sub, Bob Carver Black Magic VTA 20, Klipsch Modded Chorus II's, Grant Fidelity: TubeDAC11
Thanks for the responses. I'll let you guys know if I end up with one or not. If I don't win this one I'll be on the lookout for another. These seem to turn up occasionally. I read a review that says this amp is very similar to an ADA PTM 6150 for a lot less money.
Scan of manual sent by e-mail!
I have the 505 and the 705.
Both have pulled all the crap I have at different times with ease.
The best thing about this bunch of Carver is the ease of Bi-Amp.
Thanks to Don for going through the trouble of scaning and emailing me his owner's manual for the AV806X. After reading it I was shocked and dishartened that it clearly stated in the manual that 8 ohms is the lowest recommended impedience for this amp. Don also told me that Mr. Carver didn't design this amp but he thought it was designed well and appeared to be well built. I'm unsure as to what to do at this time. Even a used Sunfire amp is way out of my price range at this time. I have seen pictures of the inside of this amp and it does appear to be solid. I know a little bit about electronics and amplifires but don't understand why they recommend 8 ohms or higher. My HK doesn't appear to be as heavy duty but they rate it to drive 5 channels of 4 ohm load and rate it at all channels driven. It now drives 4 channels at 6 ohms and 1 channel at 8 ohms and can be played at very high volumes and throws off little heat. Perhaps this is due to the fact that the 6 ohm loads are divided up into just 2 speakers via 2 amp bi-wiring for each. The Carver would see this bi-wiring on 4 channels but the other 2 channels would be driving 6 ohm speakers that are true 4 way speakers with a small 8" sub and 6 1/2" midbass that don't have bi-wiring capability. Has anyone out there tried to drive low impedience speakers with an AV806X? If so how did it work out? Thanks.
Well, the ability to drive low Ω loads is all about current. An amplifier can't defy Ohm's law, and a transformer can only deliver so much current at its rated voltage. Now V=I×R, so when R gets small, I must go up to maintain a constant V. If you reach the limit of the amplifier to increase I as R goes down, V must go down, too, or as we call it, sag. When the rails sag the output transistors don't have enough voltage on their collectors to reproduce the music faithfully (i.e., beneath that voltage), which is one form of clipping. Clipping not only sounds bad, but can do serious damage to your speakers over time (voice coils heat up and eventually fail in one of numerous ways).
The best way to avoid this is to not demand too much from your amplifier. A 200W 8Ω rated amplifier can probably play all day without breaking more sweat at 100W into 4Ω (constant current). Remember, this is peak power though. The reason you have a powerful amp is to keep the peaks below the maximum. What I mean be constant current is, for example, a 200W amplifier could draw 5A with rail voltages of 40V, yielding 200W (5A×40V=200W). If you keep the 5A as a constant, when you go to 4Ω, you have ½ the voltage (V=I×R → V=5A×4Ω=20V → 5A×20V=100W).
It's a little more complicated than that, but that's the jist.
Yeah, what BillD said
Save your money and look for a sunfire 200X5 you will not be disappointed.
Save your money and look for a sunfire 200X5 you will not be disappointed.Re: Newbie looking for advice
Jag_97470 wrote:Yeah, what BillD saidSave your money and look for a sunfire 200X5 you will not be disappointed.
What he and him said
200X5 Sunfire NEVER DISAPPOINTS!!!
