It is currently Sat Jul 22, 2017 1:52 pm
Carver PM-175 Opinions Please
chains91
Post Thu Feb 20, 2014 8:43 pm
I've never owned Carver gear but recently came across a PM_175 power amp at a pawn shop for 110.00. I put it on lay-away on a whim with no knowledge of it. I don't see any useful reviews online and was hoping someone would chime in with their experiences or opinions on this unit. Thanks
fill35U
Post Fri Feb 21, 2014 1:05 pm
Re: Carver PM-175 Opinions Please
Congratulations on your new amp!
The PM-175 seems to be uncommon these days. I don't know how popular they were when they were being made back in the mid-'80's.
I haven't seen what they look like inside, I'm sure we would all appreciate any pics you could post!
I haven't been able to find a service manual or schematic, but *think* the PM-175 was a "one flat board" amp. Pretty sure it's a Mag Field amp, with two rails for the output stage. Possibly the pro version of the equally-rare M-0.5t?
The PM-175 was rated 175 Watts per channel into 8 ohms, stereo. It was also bridgeable in series mono with a switch (common ground outputs). Non-inverting in stereo mode.
As were most amps of that era, the XLR's are factory wired for pin 2 *cold* (-), although many were subsequently changed to the modern standard of pin 2 hot. The TRS jacks are conventionally wired and parallel the XLR's (easy to jumper for dual mono or daisy chain).
There's a provision on the back for changeable modules, such as crossovers. Might want to see if it's got something special plugged in there!
Good luck!
Post Fri Feb 21, 2014 1:12 pm
I have no experience with that amp but its a Carver and the price seems right, Congrats!!
Sunfire Theater Grand III
Sunfire Signature 625x2
Klipsch Cherry RF-5's
Return to "The Welcome Mat"
