Thorens TD 145 turntable
Re: Thorens TD 145 turntable
Post by OBI56 » Sat Aug 23, 2008 9:26 am
Brit, Thorens uses different proprietary headshells for different tonearms. This one is the TP-16 Tonearm and uses the headshell that I posted a picture of. The older series used a differently shaped headshell that was not offset. The later series didn't use a headshell at all, but the entire tonearm tube plugged into the tonearm pivot point. I'll dig up all the exact part numbers for you tonight
snarffydoggy
Post by snarffydoggy » Sat Aug 23, 2008 11:03 am
OBI you're the man, I don't know where you get all the info you come up with, but keep up the good work as it is greatly appreciated!!!!
snarffydoggy
brit01
Post by brit01 » Sat Aug 23, 2008 11:43 am
I second that.
OBI should win an award for his knowledge and help.
=D> =D> =D>
Post by OBI56 » Sat Aug 23, 2008 2:49 pm
Snarffydoggy, I have been involved with turntables since I was 14, even going as far as building my own turntable and tonearm for a science fair in grade 12. Some guys were into cars, I was into turntables.
brit01
Post by brit01 » Sat Aug 23, 2008 7:14 pm
The seller has just mentioned there is a little problem with the automatic arm! :-k :-k
He will return with more info tomorrow.
Post by OBI56 » Sat Aug 23, 2008 7:20 pm
If there is a problem like that with it, be wary. It will cost more to fix it than the price of the turntable.
