It is currently Wed May 22, 2013 12:08 am
Lightstar Owner Registration
Post Thu Dec 13, 2012 8:31 am
Re: Lightstar Owner Registration
Nate...did you ever hear back from Bob about the chip for the Lightstar pre? :-s
natektronic
Post Sat Mar 02, 2013 1:47 pm
Still waiting. Have you devised an ingenious plan to get one programmed?
Primary System:
Preamp - Carver Lightstar Direct
AMP - Carver Lightstar Reference
TT - Rega RP-1
Speakers - Definitive Technologies BP-2000
natektronic
Post Sat Mar 02, 2013 11:37 pm
So, I have been having an issue lately in my setup with my right channel cutting out. I have narrowed it down. It is the amp. I have swapped out every cable, taken the preamp out, everything. I am very worried and not sure what to do. Any advice?
Primary System:
TT - Rega RP-1
Post Sun Mar 03, 2013 2:57 am
Rolland or tom. Nobody else comes to mind.
Post Sun Mar 03, 2013 8:11 am
natektronic wrote:So, I have been having an issue lately in my setup with my right channel cutting out. I have narrowed it down. It is the amp. I have swapped out every cable, taken the preamp out, everything. I am very worried and not sure what to do. Any advice?
I believe Vintage Hi-Fi of Pittsburgh is closer to you. Call Tom around 6 pm M- Sa and see when he can get to it. As far as the chip.... no I haven't and doubt I will be able to find anyone to do it .
Post Sun Mar 03, 2013 12:43 pm
natektronic wrote:Still waiting. Have you devised an ingenious plan to get one programmed?
Bent Audio has a remote system that covers all of the functions that the Lightstar remote covers. It 'might' work. Integrating it into the system will be problematic and require someone who knows alot about the Lightstar Direct Pres.
Post Fri Mar 08, 2013 5:16 am
I now have #4
Post Sat Mar 09, 2013 8:31 am
angelod307 wrote:I now have #4
Lucky Boy!
VPI Classic Turntable (blk)
Carver Silver 7's Tube Amps
Carver TX11.
B&W 802D's Rosenut
