It is currently Tue May 21, 2013 11:13 am
For those running Lightstar amps~
Post Wed Feb 10, 2010 11:23 am
A little something I found & wasn't aware of:
Lightstar Power Amp utilizes a Carver digital transformer which provides built-in line conditioning.
You plug the amp into the wall not a power conditioner.
Post Wed Feb 10, 2010 6:03 pm
Re: For those running Lightstar amps~
Thanks Gary!! Bob did tell us at CF'08 that they also make more power if line voltage goes up. 125 volts should equal the same power as a Sunfire 600X2. IIRC
Post Wed Feb 10, 2010 6:08 pm
What does a digital transformer look like? Does it do digital floating point multiplication or division based on the winding ratio :-k
