It is currently Thu May 23, 2013 9:59 pm
HELP LIGHTSTAR
Post Fri Feb 01, 2008 1:30 pm
Dave, scroll up to TFM75s comment on Dreamer's solution which I also came up with while I was editing my response. You only need the MCT if you have a MC cartridge.
Preamp = box with knobs and switches
Phono Preamp = circuit that amplifies the phono cartridge and equalizes it to RIAA specs. Can be internal or external for pre-amps not equipped with a phono stage like your Lightstar
Pre-pre-preamp or MCT = 10db step up device ONLY needed for Low Output MC cartridges
Post Fri Feb 01, 2008 4:22 pm
Now that James Van Dyke put quieter op amps in my C-4000 phono section, I use it as my phono input to my Sunfire (rather than the Sunfire's). I also use the C-4000 as a can amp. It also takes the output from my computer through an external DAC.
Post Fri Feb 01, 2008 10:24 pm
I use the phono stage from either my C-1 or C-19 for vinyl. The tape output feeds Lightstar, and all is right in Ray's TT world 8) The tape loop on the C-19 is gain and tone free if used in the by-pass mode.
maddmaxxx
(Pair of Silver 9t's)
Post Sat Feb 02, 2008 12:03 am
-the ONLY time i've needed TT 'blk boxes' are w/MC carts[the hi output ones too]
-never yeti, w/MM carts
-heard that some recievers[amp, tuner, pre= combined], had 'falsified' phono inputs[read manual]
-* © Küül ®™ /mx...
-Too hip gotta book
