Lightstar Direct XLR Outputs - Low Gain?
Is this normal for the Lightstar, or is something amiss?
Thanks!
It is currently Fri May 24, 2013 12:27 am
whell wrote:On my Lightstar Direct preamp, the balanced outputs seems to be quite a bit less (quieter) than the RCA outputs. When using the balanced outs, I really have to crank the preamp up. I'm using a PS Audio Trio A 100 amp, which has balanced inputs (and yes, I've set the switch on the back of the amp to the XLR inputs).
Thanks!
DaveS wrote:This is right from the owner`s manual:
Balanced Output
These provide a true balanceoutput which can be connected to the balanced input jacks of a power amplifier. There is no gain from the balanced or unbalanced inputs to balanced output, only attenuation that is determined by the amount indicated on the front panel.
Dreamer wrote:Perhaps he needs to get some sort of buffer amp to put between the pre and the amp, or his CD player and the pre to bring this signal up to a "proper" level?
Musical Fidelity's X10-v3 is a fantastic unit, and it's made with typical British attention to detail. And there are dozens of "pro" model buffer amps out there, some better, some not so good, that can be had cheap if you buy used.
Just a thought...
--Richard
Dreamer wrote:Did I see somewhere that you are using a Carver SDA-490t CD player?
--Richard
Toy Maker wrote:Have they always been low... or is this something new ?
Do you have any other XLR sources hooked up the the preamp? if not try something else, and see the it's the preamp input, or the CD output.
Also, try a different set of inputs, I think there are 3-4 sets of XLR's
DaveS wrote:Unbalanced Output
The balanced signal inside the Lightstar Direct is converted to a unbalanced output by a precision instrumentation amplifier with a DC servo circuit to minimize DC offset. This circuit also provides 20 dB of gain to the signal. However, there are two internal mini-link jumpers that can be changed to reduce the gain at the unbalanced output to 0dB (see instructions for changing the unbalanced gain on page 12)
