It is currently Sat May 25, 2013 8:14 pm
Need Help with my new Ultimate Reciever
mr3putt
Post Wed Jan 06, 2010 8:33 pm
Spent the afternoon tearing down the old system and hooking up the new.
All of the audio inputs seem to work but I can't get the On Screen Display up to program all of the options.
For various reasons I decided not to run my Video Sources (FIOS and DVD) through the Ultimate. I was attempting to feed the OSD from the UR to my Samsung HDTV by connecting from the Main Video Out to an AUX IN on the TV. No Joy.The documentation stinks on the Samsung so I can't be sure if that connection is composite or not. The TV seems to sense a signal but won't display bupkus
Is it possible to program without the OSD?
Do I have to route my video sources through the Ultimate to enable the OSD?
Inquiring minds want to know
Thanks
Sunfire Ultimate Reciever & Sunfire 300x2
Carver HR 895-TFM 15
Carver 490t CD
Carver 1770 Tape
Sunfire CRM-2's - 1 Pair
JBL-L100's
NHT Satellites-2 Pairs
Klipsch Sub
Technics SL-QD33 Turntable
Post Wed Jan 06, 2010 9:16 pm
Re: Need Help with my new Ultimate Reciever
The answer to the last question is no. You have to select on the Ultimate (if it's like the TGP-III) whether your output is S-video or composite (and whether it is on Video 1 or Video 2). Then attach the cable to your TV from the appropriate video connection on the Sunfire using the appropriate type of connection. Then, put your TV on that input and press Menu on the remote. You can do it by looking at the display on the Sunfire, but the menus are much abbreviated and confusing.
weitrhino
Post Wed Jan 06, 2010 9:55 pm
I am also relatively new to the UR and have not set it up for HT use, but I get the OSD directly from the main out using a composite input to the TV. If the port on your Samsung is yellow, then it should be composite video. Page 30 of the manual states:
The On Screen Display (OSD) is present at the composite video or S-video MAIN outputs. It is also present at the output labeled VID2/MON2, but only if it is set to MON2. Make sure that your TV monitor's video input is connected correctly to one of these outputs.
OSD is NOT available on the component video. Make sure you connected your composite cable to the output of the UR.
mr3putt
Post Wed Jan 06, 2010 10:40 pm
Thanks to all
As usual this forum is fantastic
I will give it a shot tomorrow
Carver 490t CD
Carver 1770 Tape
JBL-L100's
Klipsch Sub
Post Wed Jan 06, 2010 10:59 pm
The other post are correct, but in my research on LCD's I found the Samsung did not have an S-Video input?? I use from my TGP-III the S-Video main out to my S-Video in on the TV (not Samsung). It does sound like you will have to use Composite > and make sure you select composite in the Samsung settings. Good luck
mr3putt
Post Thu Jan 07, 2010 8:32 pm
Status update
Thanks to the sage advice recieved from the board I successfully enabled the OSD
Programmed the settings as required and fired this puppy up
The results.......
Unbelievable!!!!!!!!!!!!!!!!!!!
I am in awe of the fidelity and limitless power of this beauty.
Within a half hour of launching this missle the cops were at the door with a noise
complaint \:D/
This in a house buttoned down for winter on 2 acres.
Sunfire......There truly is no substitute =D>
Carver 490t CD
Carver 1770 Tape
JBL-L100's
Klipsch Sub
Post Thu Jan 07, 2010 11:59 pm
Congrats!
It's addicting, ain't it?!?
Post Fri Jan 08, 2010 12:18 am
mr3putt wrote:Status update
The results.......
complaint \:D/
Great! Congratulations! The cops came? That is fricken Awesome!!! \:D/ \:D/ =D>
Post Fri Jan 08, 2010 5:33 am
My record is on a corner lot I had a guy come from seven houses down to tell me his kids couldn't sleep (9 pm on a Saturday night).....
mr3putt
Post Fri Jan 08, 2010 1:11 pm
TNRabbit wrote:Congrats!
Worse than Crack :D
My wife is scared stiff just watching me play with this toy
She knows the obsession is just beginning
Great cure for cabin fever though \:D/
Thanks again for all who aided my installation
Carver 490t CD
Carver 1770 Tape
JBL-L100's
Klipsch Sub
mr3putt
Post Fri Jan 08, 2010 1:14 pm
TNRabbit wrote:My record is on a corner lot I had a guy come from seven houses down to tell me his kids couldn't sleep (9 pm on a Saturday night).....
Did you suggest some fabulous Bose Noise Reduction Headphones ? :lol:
Next time the police show up I will invite them in for a beer and a listen.
No one who has heard this system would convict me \:D/
Carver 490t CD
Carver 1770 Tape
JBL-L100's
Klipsch Sub
Post Fri Jan 08, 2010 5:09 pm
mr3putt wrote:Next time the police show up I will invite them in for a beer and a listen.
It's not convict me, it's evict me!! :lol: :lol: :lol: :lol:
mr3putt
Post Sun Jan 24, 2010 2:52 pm
Some observations of my new Sunfire Ultimate
I have noticed a significant difference between Source Direct Mode and Party Mode
In Party Mode the Input Gain strength seems dramatically weaker resulting in a slightly muffled
effect lacking dynamic range. This was true with all sources (Tape-Both Cd Players-TT)
I have mitigated this significantly by changing the output from my 490T to the variable output connections and juicing up the gain. That works like a charm. There appears to be no similar option within the Pre Amp stage of the UR. You can only reduce, not increase, line input signal from any source in any Mode. I realize that Source Direct bypasses all of the digital proccessing but would that overhead itself be the cause of reduced input signal strength?
Just curious.
I am probably the only fool around who uses this beast primarily in Party Mode in lieu of Source Direct 2 channel. This due to room size and acoustics as well as a masochistic desire to watch the pictures and plants dance along with me as I revel in the sonic power \:D/
On another note: Does anyone lnow the device code to enter into the remote to control the 490T? Cycled through the range but the CD never turned on.
Thanks to all
3putt
Carver 490t CD
Carver 1770 Tape
JBL-L100's
Klipsch Sub
Post Sun Jan 24, 2010 3:51 pm
What speakers are you running in party mode? It was my understanding that party mode played "all" speakers including the center and surrounds at the same time. don't know about your remote, but on my TGP-III there was no code found for our older Sony VHS player, but there is a series of buttons pushed aiming the remote to "manually" program any button you desire to run functions. Maybe look in the manual programming the remote manually?
Post Sun Jan 24, 2010 4:30 pm
Well, you'd think that splitting the signal φ times would have some effect on gain (like φ times -3dB)
