It is currently Thu May 23, 2013 10:47 pm
HELPWith Bose EQ Hookup
Post Fri Dec 31, 2010 10:07 am
Re: HELPWith Bose EQ Hookup
walleyeguy wrote:Hey thank's for the Info Thing is I wanted to Run 2 Amps and wont be able to doso with them hooked like that .I Think? Anyway I did Something to My Pre-Amp Have No Sound Comming Out of it Tried several Differnt Amps and Nothing Just Very Faint When turned Up to Extreme Levels...Not sure What to Do Now Just Bought More Carvers but will not be Running them For a While :( I Was Hoping to Hook them to An old Pioneer I am Using But unsure How to Connect the amps ..It has Jumpers And I'm not sure ? ...Thanks ....Happy New_year..............
I have an Old Classic Pioneer SX-1250 receiver that also has jumpers. If you remove the jumpers, this will allow you to compare different amps and/or pre-amps to the Pioneer. Just insert the Carver and this will enable you to still use the Pioneer pre-amp and compare vs the Pioneer amp.
What model Pioneer receiver? Still have my Original Pioneer manual that explains this. If you PM me your e-mail, I can scan and send to you this section.
walleyeguy
Post Fri Dec 31, 2010 11:33 am
I Live in NW Ontario Canada . And What I Did was Disconnect the KW Amp and Bose EQ And Attempted to hook up the 1.0T That I Had Just Bought and Never Used Then when I powerd up 28V I had a Muffled Sound With Little Sound ? Then I Started to Trouble shoot By switching Amp's Around And Did not Wait long enough and When I went to Plug in The RCA cable It Let out A Loud Bang Had it Happen B-4 Never caused a Prob. Not sure what To Do Sadly I was Packing My Equepment into The Garage for Storage For Now:(. Does anyone Know of a Place in Canada That Does Good Work on Carver? Thanks......
Post Fri Dec 31, 2010 11:42 am
...That ain't good. :-({|= ...check all the fuses first. NEVER swap components without shutting EVERYTHING down first.
walleyeguy
Post Fri Dec 31, 2010 11:43 am
Hi Thank's for the Info I have A VSX9500s and my Problem Is that I do Not Know which side to Plug the Amp into ? It says Pre-Out and Power In Not too sure What to Plug the Power Amp into ?Its Jumped White to white And Red-Red Also Tried to use the Tape 2 Mon but Cant Figure it out Either ...Need it for My Bose EQ ..Hope 2011 Starts Better......Cheers
walleyeguy
Post Fri Dec 31, 2010 11:47 am
Hey KingMan I Know Better I Had Powerd it Down But My 1.5 Takes a While ...So you Think there is Fuses in The Pre-Amp Sure would be Nice ....If not I will have to Find A Place that Can Fix or Check it out ...Thank's
Post Fri Dec 31, 2010 2:59 pm
There's a guy called Anatech up there that knows his Carver. He's a member on this forum and has an email address listed.
walleyeguy
Post Fri Dec 31, 2010 7:06 pm
Thanks I'll look him up
Post Fri Dec 31, 2010 8:38 pm
walleyeguy wrote:Thanks I'll look him up
There's another member in Canada who does good work: musinteg. check under the members tab.
walleyeguy
Post Sun Jan 02, 2011 1:11 pm
Happy 2011 Looked for The Member But can't seem to Find That Member In the List ....But I Will try to Find some one In Winnipeg that Might be Able to Help Me out ? Anyone Know of Any Place out West ? Thank's ..........
Post Sun Jan 02, 2011 2:23 pm
walleyeguy wrote:Happy 2011 Looked for The Member But can't seem to Find That Member In the List ....But I Will try to Find some one In Winnipeg that Might be Able to Help Me out ? Anyone Know of Any Place out West ? Thank's ..........
Try this link:
memberlist.php?mode=viewprofile&u=8262
