It is currently Sat May 25, 2013 6:51 am
MY SD/A 390T
Post Tue Feb 15, 2011 1:19 am
MY SD/A 390T
Hi guys, my 390t is starting to skip once in a while, thinking it needs the laser cleaned but not quite sure how to do it, think thats the problem? or should I just send it out to rita for a tune up? let me know what you guys think, thanks, frenchguy :-)
Post Tue Feb 15, 2011 8:05 am
Re: MY SD/A 390T
I haven't torn mine apart but you could first try one of those insertion cd's that have fluid and the little brushes on them. Around $5.
Post Tue Feb 15, 2011 8:17 am
Re: MY SD/A 390T
PURE alcohol (NOT rubbing alcohol!) & a cue tip will take care of it. about 6-7 screws will pop the top, then there's a screw in the center that holds the CD stabilizer on. Remove that & you'll have clear access to the lens.
Post Tue Feb 15, 2011 8:22 am
Re: MY SD/A 390T
Don't use alcohol... Very Bad for plastics.
Get this stuff... It's MADE FOR PLASTICS.
the blue one cleans and polishes plastic... It also cleans anodized aluminum AMAZINGLY
http://www.novuspolish.com/
Post Wed Feb 16, 2011 2:19 am
Re: MY SD/A 390T
I used a Clear Plastic lens cleaner on my 390t and its Rock-in and Rollin...
I also took my Blower and used low but enough pressure to clean out the Dust - Look like New now \:D/ \:D/ \:D/
