Silver Seven
It is currently Fri May 24, 2013 2:43 pm
F1nut wrote:The Manley Ichiban tube mono blocks put out at least 600wpc and they also made a custom 1000wpc version.
The Ichibans were triode strapped for about 200 watts output power
One thing about the Manleys is they always used some weird ohm like 5 or something to list their wattage specs while everybody else starts off with 8 ohms.
F1nut wrote:The Ichibans were triode strapped for about 200 watts output power
Oops, I had them mixed up...thanks.One thing about the Manleys is they always used some weird ohm like 5 or something to list their wattage specs while everybody else starts off with 8 ohms.
Tube amps are a little different than SS amps when it comes to the power ratings. Tube amp power ratings generally don't change much with the load.
BillD wrote:Jesse's right, because tube amps are primarily current sources (transconductance) rather than the voltage sources (transimpedance) that solid state amplifiers mostly are.
Transconductance amplifiers produce output current proportional to the voltage input. As such, they are known as voltage controlled current sources.
Transimpedance amplifiers produce output voltage proportional to the current input. Thus, they are called current controlled voltage sources.
