It is currently Sat May 25, 2013 3:57 am
Carver M-500t sound - What was it cloned from?
stereo_buff
Post Tue Mar 01, 2011 3:48 pm
It is well documented that the Carver M-1.5t sound was patterned after that of the Mark Levinson ML-2 and that the M-1.0t was patterned after a Conrad-Johnson Premier Four. What about the M-500t? What was the 'reference' amplifier that its sound was supposed to emulate? Interestingly, the M-500t manual simply states that "Your M-500t uses the T-mod technology originally developed for the Carver M-1.5t power amplifier." Does anyone know for sure? Thanks.
skip
aka (Sasquach)
Post Tue Mar 01, 2011 4:19 pm
Re: Carver M-500t sound - What was it cloned from?
Nope. I just know it sounds different than any other Carver amp I've heard.
Sasquatch
Post Tue Mar 01, 2011 10:11 pm
The M-500t was not made to emulate any amp.
Post Tue Mar 01, 2011 10:20 pm
Rita told me that the "T" mod was an upgrade offered to the original "M" series amplifiers and were later put out as a second offering of basically the same amplifier. The original M-1.0 or M-1.5 could be sent back to the factory to be re-wired with monster cable and a couple resistor changes, which came that way in the later "T" models or M-1.0t & M-1.5t respectively. It had nothing to do with the transfer fuction calibration.
Post Tue Mar 01, 2011 10:28 pm
I thought the Monster wire myth had already been silenced???
Post Tue Mar 01, 2011 10:45 pm
kingman wrote:I thought the Monster wire myth had already been silenced???
You have to remember that I'm fairly new here, please enlighten me! :D
Post Tue Mar 01, 2011 11:07 pm
Nothing more than a marketing ploy to sell more amps. Lift the hood on any of them that say "Internally Wired With Monster Cable" and tell me if you see any difference from regular #14 gauge wire.
Post Tue Mar 01, 2011 11:19 pm
Well sure, but they put the stickers on right? I was referring to the "T" after the M-1.0 for example. That's what the "T" mod represents is the "UPGRADE" wheither it was actually done or not is really not the point I was trying to make. The M-1.0 was still transfer function calibrated, the "T" was the whole Monster Cable and resistor change. Atleast that's what I gathered through my conversation with Rita.
Post Tue Mar 01, 2011 11:23 pm
Monster cable...it's like the unicorn...it simply didn't exist...transistor maybe, cable no.
Post Tue Mar 01, 2011 11:25 pm
Wrong. The T stands for Transfer Function Modified or Calibrated.
The Monster thingy was totally different. I think it was done after Bob left !
Post Wed Mar 02, 2011 12:45 am
IIRC, there was some 14 ga. Monster Cable used to go from the amplifier board to the binding posts. That's it.
Post Wed Mar 02, 2011 8:29 am
Thanks Bill for setting me straight! =D>
Post Wed Mar 02, 2011 8:39 am
BillD wrote:IIRC, there was some 14 ga. Monster Cable used to go from the amplifier board to the binding posts. That's it.
And that was only on a very few models.
stereo_buff
Post Wed Mar 02, 2011 9:33 am
My M-1.5t has the 'Monster Cable improvement' (as evidenced by the decal on the rear panel) and it is just like Bill said - a short piece of 14 AWG cable going from the amplifier board to the binding post. It's just marketing...
