It is currently Sat May 18, 2013 4:20 am
auto on compatibility
Glenlivet
Post Thu Mar 31, 2011 6:28 pm
Hey, does anyone know whether the TGP-5 can be used to power up a PM1.5a?
The PM1.5a is being used in a bi-amp setup, on the low end and driving Infinity K9's. (That is, it will until fate and great good fortune shall direct me to a 600-2 that I can acquire to do that! :D )
It is a PIA switching all kinds of equipment on and off each time I power up the sound system (as I'm sure we all appreciate) and I'm rigging a power bar to activate through a 40 amp (at 12 volt) relay to be turned on by the 12 volt output on the TGP-5 when it powers up, the way that processor turns on its companion TGP 400-7.
I don't want to run the PM1.5a on this relay as well though, due to the greater current needs of a power amp and in fear that this might overload the relay. I'd like to use the Carver power up system for the PM1.5a, but the problem comes with labeling and what it really means.
The TGP-5 output is logically indicated to be 12 volts and the terminals are clearly marked, 12 volts positive and negative, not to draw more than 500 Ma total.(The TGP 400-7 only draws 20 Ma.)
The PM1.5a however has low voltage terminals on the back for it's start up 'sequencer' that are marked 'receive' and 'send'! (huh?) I have no manual for the PM1.5a.
What does receive and send mean?
Are these things compatible and can the PM1.5a be switched on by the TGP-5's 12 volt output?
Thanks
Post Thu Mar 31, 2011 6:47 pm
Re: auto on compatibility
On the PM-1.5, the positive terminal takes +6 to +22 Vdc and 2 to 4 mA to the green (receive). The send generates a signal after the one triggered powers up to sequence the next in a rack of these puppies.
Glenlivet
Post Thu Mar 31, 2011 7:47 pm
The 12v. + to 'receive' and the negative... to chassis ground?
Post Thu Mar 31, 2011 8:54 pm
From the PM-1.5 Service manual
PM-1.5 startup.jpg (122.58 KiB) Viewed 382 times
Glenlivet
Post Thu Mar 31, 2011 10:39 pm
Thanks for posting that! Should be straight forward from here on. \:D/
Post Thu Mar 31, 2011 11:51 pm
so, if you use one of these, granted you know how to wire it up, it will turn on anything with the 12v output of the tgp. as a matter of fact, they also have a 120v version that will do it with pre's or what not that have a switched power output. granted that you will need a project box as well unless there is room in the amp for the relay.
http://www.mouser.com/ProductDetail/Omr ... vWDg%3d%3d
Glenlivet
Post Fri Apr 01, 2011 12:27 am
Thanks, I have all the hardware already. :D It's just a couple hours building it. The TGP-5 will power up everything when switched on either with the panel button or the remote. (except the turntable, media player, or TV)
