It is currently Sun May 26, 2013 1:47 am
Carver Mono blocks Silver 7 t and common Ground
jbfan77
Post Fri Apr 08, 2011 6:02 pm
These amps are not common ground right? I have them connected to the Polk 1.2's with the negative tired together.I also have the infinity Kappa 9's.when connected to theses should I have the negative tired together,as well... I'm a little confused about the common ground thing. thanks guys
Post Fri Apr 08, 2011 7:10 pm
Re: Carver Mono blocks Silver 7 t and common Ground
Typically,,mono's are not common ground--now with the Polks--and mono's-- you can strap the amps together,such as you have done--or in other cases,use or buils a "non-common ground" interface that goes in place of the standard SDA interconnect.I'm not sure,,but I don't think that it matters with the Infinity's,,if you choose to build a non-common ground interface,,the buils can be seen here--
http://www.polkaudio.com/forums/showthread.php?t=74472
Post Fri Apr 08, 2011 7:21 pm
Common ground means both channels share the same ground. Sounds like you're right.
Post Fri Apr 08, 2011 7:31 pm
Can the 7t's be run this way?
Post Fri Apr 08, 2011 8:43 pm
Most monoblocks drive both the positive and the negative (ground) simultaneously but inverted. Think of a sine wave on one wire and it's inverted cousin on the other. The amplitude of each is the opposite so, if I were observing the positive signal sitting on the ground signal, it would be twice as big. Now, the other monoblock is doing this also, and their grounds are clearly not "common".
Post Fri Apr 08, 2011 11:11 pm
jbfan77 wrote:These amps are not common ground right? I have them connected to the Polk 1.2's with the negative tired together.I also have the infinity Kappa 9's.when connected to theses should I have the negative tired together,as well... I'm a little confused about the common ground thing. thanks guys
Clyde, is that you?
jbfan77
Post Sat Apr 09, 2011 2:50 pm
Clyde, is that you?
Hey,,,,it's me,nice to see you over here....
Post Sun Apr 10, 2011 2:18 pm
Yeah, I knew it was you.
You should really use the AI-1 as strapping the grounds diminishes the sound quality.
Post Sun Apr 10, 2011 2:23 pm
May the force be with you.....
Welcome to the Carver forum! I sense some good with this one, Jesse.
jbfan77
Post Tue Apr 12, 2011 2:35 pm
F1nut wrote:Yeah, I knew it was you.
That's what I heard,but I have to find one.
Post Tue Apr 12, 2011 2:49 pm
You should have kept the one you had.
Post Tue Apr 12, 2011 4:49 pm
Troy on Polk forum is selling some A1's
jbfan77
Post Tue Apr 12, 2011 6:13 pm
F1nut wrote:You should have kept the one you had.
I was getting a lot of static from it,that's why I sent it back.
Post Tue Apr 12, 2011 6:29 pm
The problem was the loose binding post on your one amp. The AI-1 worked perfectly.
engtaz wrote: Troy on Polk forum is selling some A1's
They sold within minutes. One of them was the one jbfan77 had.
jbfan77
Post Tue Apr 12, 2011 8:21 pm
That's what I was told,,, but I'm happy with my sound now,since I upgraded my Cables to the MIT Shotgun(s).it hard to think,my system would sound any better.Not getting any static now... Hopefully,I will get the opportunity to find another AI - 1 Cable. F1NUT,I didn't know what else to do but send it back. Ted tried to fix it.he put electrical take around it. Do I need to keep the Amps Tied together when playing through the Kappa's... thanks
