It's called "High FIDELITY" and not "High Whatever Sounds Best to You" for a reason Kingman. High Fidelity is that "threading of the reality needle" that we all (amp/speaker/system designer's AND listeners) strive for and is what guides us all to a better system. Other wise what would have been the point of the Carver challenge, e.g.? Bob would have just put some pot adjustments in the back of his amps and instructed the end user to just "tweak it until it is Whatever Sounds Best to You"....
I have been sitting here the past few days reading this post.
I'm a bit confused.....
"High FIDELITY", I think we all can agree that most if not of our systems kick ass, when you compare them to the average crap that most people have.....
if on my system I like the way it sounds to me, gives me hrs of pleasure, then for me its good.
but the same system may sound like ASS to others, why.......who the hell knows.....
does that make me right or them wrong?.....
no..
as to whether sunfire sounds better than carver?
I can only say that I only have carver in my system, have I heard sunfire, ....
yes,.....
did it sound good,......yes (Eddies system)
I would need to really have a component hooked up to ALL my stuff to know if would sound good....
I'll use the PL amp as a reference, these had a problem of flaming on....
then carver tfm amps. on mine all three have failed at some point, did they flame, no.....
the parts just failed....
then the sunfire..... I have not heard/read about to many of the amps even going dead or dying.
the reason to me is this....
as all 3 brands have the same designer, and as time goes on he got better at knowing what works and will last.....
does this mean that the sunfire will sound better than a PL?.....
I kinda think it would, that is kinda the way of things as time goes on, ya try and make things better,(think sound) not worse....
it 's that way with pkg machines, cars, boats ,planes and amps.....etc
but does the carver sound better to you than a sunfire with ALL your stuff in line, yes to you.
I can understand this, but would it sound better with my stuff, who the hell knows....
as to the pot adj., if you think tubes you can do this very thing, swap out to a different tube, this can change the sound.....
better, worse?.......
who's to say.........
