It is currently Sat May 25, 2013 1:46 pm
So if you had the choice...
HRDROKN
Post Sat May 21, 2011 2:39 am
So we moved again.... this is a good thing!
I have a dedicated 220V circuit available that I would split into 110V to run my gear. So if the choice was between a 20' power cable with 20 amp service from source, a 20' balanced interconnect from crossover to amps and short <6' speaker cable as one option or less than 5' interconnect and power with 20' of speaker cable as another... which would be better?
HRDROKN
Post Sat May 21, 2011 3:46 am
Re: So if you had the choice...
Run the 110v as far as you can, 2x 20-30amp services
Post Sat May 21, 2011 6:43 am
Toy Maker wrote:Run the 110v as far as you can, 2x 20-30amp services
hrdrokn
I would say the same, but remember the shorter the speaker cables are the better.
I ended up running 20x20 amp circuits to my Cherry 260's but still needed 20ft speaker cable.
Brian.
BTW nice to see you posting again.
VPI Classic Turntable (blk)
Carver Silver 7's Tube Amps
Carver TX11.
B&W 802D's Rosenut
HRDROKN
Post Sat May 21, 2011 10:11 pm
Thanks for the advice guys... I'm going to roll with it!
HRDROKN
Users browsing this forum: Bing [Bot], Snoop65 and 1 guest
