It is currently Sun May 19, 2013 6:32 pm
Carver C-9 and Onkyo Receivers 9.2 THX
jck
Post Mon Jun 20, 2011 8:51 pm
Question--can the C-9 be used effectively with current home theatre systems such as an Onkyo unit? I have a high-end unit (TX-NR3007) used as a preamp to feed my Sunfire amp for my mains and wanted to know if anyone has experience with this type of issue. I remember hearing the c-9 in the early days and wow. I though about running the Onkyo into the C-9 and then into the Sunfire…are they true bypass? Any comments on this will be appreciated.
Post Tue Jun 21, 2011 4:54 am
Re: Carver C-9 and Onkyo Receivers 9.2 THX
If the Onkyo has an EQ in/out or tape monitor, that might the place to put it, but yes, you can run between the two units as well.
Post Tue Jun 21, 2011 11:07 am
For music it should work fine. For video soundtracks in 5.1 where dialog is centered, maybe not so much.
