Page 1 of 2
AL-lll life span
Posted: Fri Jul 08, 2011 9:53 am
by 67ih4x4x4
My wife likes to listen to the radio in the background all day. Should I be concerned about the hours being put on the AL-lll's , I can set up a separate amp /speakers combo if needed.
Re: AL-lll life span
Posted: Fri Jul 08, 2011 10:01 am
by kingman
67ih4x4x4 wrote:My wife likes to listen to the radio in the background all day. Should I be concerned about the hours being put on the AL-lll's , I can set up a separate amp /speakers combo if needed.
No
Posted: Fri Jul 08, 2011 10:16 am
by Toy Maker
Not at all... Play them till they fall apart :lol:
Playing them at a low volume all day, will do no more damage than leaving them off all day.
Now... If she's dumping 400w into them all day, that might be a different story =D>
ALL electronics have a shelf life, some day, no matter if she used them all day of lets them sit all day, they will need a little "face-lift"
foam surrounds, ribbons, caps. They ALL will fail some day, even if they were all brand new, still in the box and never used.
Electronics have their own form of Cancer ](*,)
Posted: Fri Jul 08, 2011 12:25 pm
by BillD
Electronics likes to be run. Even "wear" parts like electrolytic capacitors actually last longer if they are in use than when they are not.. What kills semiconductors is overheating. Played at modest levels (well in their safe zone), they could last forever. The same goes for ceramic and film caps, although some film caps do have life spans in the hundreds-of-thousands of hours. Same with resistors. AL-III ribbons have little that can go wrong with them at low levels. The woofer surrounds will deteriorate over time, but can be fixed. If only Bob had found woofers with butyl rubber surrounds!
Posted: Fri Jul 08, 2011 2:29 pm
by kingman
...Hence the Infinity 10.1 perfect upgrade!!! \:D/
Posted: Sat Jul 09, 2011 9:21 am
by 67ih4x4x4
The Infinity 10.1 are discontinued right?
Posted: Sat Jul 09, 2011 10:55 am
by BillD
Yes, but they sometimes show up on eBay.
Posted: Mon Jul 18, 2011 4:12 pm
by Planerguy
If you don't push them to hard, they'll last a very long time. The ribbons of course can be repaired/replaced, and the 10" woofers are really not not a problem to keep them working, or they can be replaced with something better. I always felt the downward firing low end was boomy, and could be greatly improved. In fact, that open slot could be used to make a front firing, slot loaded woofer system........ Something I may look into actually.
Posted: Mon Jul 18, 2011 6:41 pm
by OconeeOrange
#-o #-o
This forum is dedicated to keeping old junk going forever.
:lol: :lol: :lol:
Posted: Mon Jul 18, 2011 7:41 pm
by Scarabeo
Planerguy wrote: and could be greatly improved. In fact, that open slot could be used to make a front firing, slot loaded woofer system........ Something I may look into actually.
I always thought about putting a passive where the Woofer is now and a side firing woofer and plugging that hole! That is the Easy way to go and I am lazy!
Posted: Tue Jul 19, 2011 8:44 am
by Eddie
OconeeOrange wrote:#-o #-o
:lol: :lol: :lol:
This form is dedicated to keeping Bob Carver's gear running for ever not old junk going for ever!!!!! My stuff is not junk!!!!!
Posted: Mon Jul 25, 2011 6:18 pm
by Planerguy
I have an idea, but I'm moving it to the Carver speakers forum, should anyone carfe to check it out.
Posted: Tue Jul 26, 2011 5:04 am
by 1044InProgress
:lol: :lol: :lol:
Posted: Fri Jul 29, 2011 12:10 am
by angelod307
19 years and counting.
Posted: Fri Jul 29, 2011 5:52 pm
by 67ih4x4x4
Thanks for all the info! My wife is out of the house right now so I might take a little off of their life!
