It is currently Mon May 20, 2013 11:57 am
They just Break
mr3putt
Post Sun Jul 10, 2011 7:31 pm
They just Break
I have owned an Hr 895 and a Tfm-15 and an Ultimate Reciever
ALL have Crapped OUT
Don't push them hard
They just fail
2 grand into power and have only a right channel left to show
Not mpressed with Bob Carvers designs
Just sayin boys
Broken shit
Sunfire Ultimate Reciever & Sunfire 300x2
Carver HR 895-TFM 15
Carver 490t CD
Carver 1770 Tape
Sunfire CRM-2's - 1 Pair
JBL-L100's
NHT Satellites-2 Pairs
Klipsch Sub
Technics SL-QD33 Turntable
1044InProgress
Post Sun Jul 10, 2011 7:37 pm
Re: They just Break
When you say "push them hard," do you mean push them beyond what they are designed for, for longer periods of time than should be?
It's just weird that all of your amps are failing..
Post Sun Jul 10, 2011 7:41 pm
Re: They just Break
Sorry you've had bad luck! I'm sure the design Isn't to blame.
mr3putt
Post Sun Jul 10, 2011 7:56 pm
Re: They just Break
Honest
An Ultimate running 4 channels and fails
An Hr 895 running 2 channels and fails
The TFM -15 was running 4 ohm load and failed- ok
I will say that load was exessive
Lots of effort and money here and can't keep a config working
Like the sound
Hate the break
Going MAC for the money
Sick of recabling
Enjoy your gear
Good luck
Carver 490t CD
Carver 1770 Tape
JBL-L100's
Klipsch Sub
Post Sun Jul 10, 2011 8:04 pm
Re: They just Break
I too have been through many audio things from my first record player in 1960.
Let me think -- #-o
I presently have 3 Carver amps, 2 SunFire amps, 2 Carver preamps and some Sunfire speakers.
I can see how at some point these might need to be refreshed.
I push my gear hard and much of it is on the deck in +100 or freezing, maybe a rain splatter in a storm.
It all works hard and sounds exceptional.
If you have a better option, tell me about it.
Everything breaks, but so far after years of abuse - none of mine have.
mr3putt
Post Sun Jul 10, 2011 8:12 pm
Re: They just Break
You are more fortunate than I
Can't afford Mean time between failure rates of 20 hours
I work electronics
Rotten performance
Carver 490t CD
Carver 1770 Tape
JBL-L100's
Klipsch Sub
Post Sun Jul 10, 2011 8:18 pm
Re: They just Break
mr3putt wrote:You are more fortunate than I
I work electronics
Rotten performance
Good deal - if I were not on probation, would question your motives on this post.
I have to watch what I post here for a couple days.
Seems like a thread with an agenda.
Did Bob once fuck your wayward wife or something like that ??
Post Sun Jul 10, 2011 8:19 pm
Re: They just Break
WoW! That's some pretty bad luck Mr3putt....I do not think I have ever "blown up" an amplifier in my life. knock-wood!
It DOES seem like he has an agenda of some sort.... :-k :-k :-k
Post Sun Jul 10, 2011 8:25 pm
Re: They just Break
I work electronics
Rotten performance
Thanks for the heads up --
Bob is a gentleman of the highest caliber.
This guy's wife was a liar. :-"
Post Sun Jul 10, 2011 8:39 pm
Re: They just Break
I work electronics
Rotten performance
I'm guessing that rather than us being lucky, you may be unlucky.
I have accumulated (2) M400t's, (1) M500t, (1) C-1 Pre, (1) Tx11a Tuner, (1) Sunfire TGP III, (1) Sunfire 5400 amp, A pair of Amazing Loudspeakers silver edition and a pair of Sunfire CRM ribbon speakers. This over a 30 year period.
Unlike you I do push them hard on a regular basis and other than replacing the woofers/foam on the Amazings I have never had a Carver product fail.
On the contrary they are very resiliant.
Maybe you pissed of a witch doctor or just a witch.
Either way, good luck with your McIntosh,
Very pretty but overpriced/underpowered & sound like ass.
It's been a pleasure.
Post Sun Jul 10, 2011 9:22 pm
Re: They just Break
none of my carver amp's has blown up.
I did buy one that have bad caps, that said these amps are 20+ years old, the caps will start to fail.
Post Sun Jul 10, 2011 9:32 pm
Re: They just Break
Mr3putt- do you have your amps protected electrically? Maybe you have a surge problem from power company or your line keeps getting hit by lightning..... :-k I had 2 amps fried from lightning in the past then I got smart and got power conditioning gear.
I have never heard of a Carver or Sunfire amp just blowing up for no apparent reason.....Bob's circuits are designed to provide power like no other- unless you are spending 10x the money!
HRDROKN
Post Sun Jul 10, 2011 9:48 pm
Re: They just Break
IDK.... I feel like I pretty much beat on my stuff on a regular basis! Amps running so hot that they would fry eggs! Tripping out ect... Never has one failed to play after a cooling off period. :lol:
Since I have increased my amplifier power, I'm in a better spot.... amps now run warm and I can play till the frigin cows come home! Whenever that is?
Love my Carver gear!!!
8)
HRDROKN
Post Sun Jul 10, 2011 10:10 pm
Re: They just Break
my tfm 15 crapped out. turns out that it needed some new caps and it was up and running again. just a thought as the caps do have a life span. i can testify first hand. been there, done that.
Post Sun Jul 10, 2011 10:16 pm
Re: They just Break
My C-500 had some early problems, probably because it was the first amp Carver Corporation put out and mine was an early serial number. The had the power supply cap voltage too low, and it kept crapping out and taking some output devices with it. Once they upped the voltage on the caps to 95V (I now have 100V caps in there), the problems went away.
