It is currently Sat May 25, 2013 4:04 am
SD/A-360 any good?
mjcmt
Post Sun Sep 18, 2011 2:37 pm
SD/A-360 any good?
Is the Carver SD/A-360 any good? It is only a 1 bit player which in general are poor sonic performers.
I have a friend who has one available, so what are they worth? They are priced high on ePay and no one is buying them.
Post Sun Sep 18, 2011 2:44 pm
Re: SD/A-360 any good?
I've bought a hand full of them off of eBay for around $75 each shipped. I like them personally and several of my friends use them without complaints.
Post Sun Sep 18, 2011 2:58 pm
I've had around 4 of them. It's a pretty good sounding player.
Post Sun Sep 18, 2011 5:43 pm
Very nice sounding player.
Post Sun Sep 18, 2011 5:59 pm
I have 1 and it sounds good. TNrabbit has one I just heard at Carverfest and it sounded very good.
Post Mon Sep 19, 2011 3:08 pm
I run mine with an outboard DAC, which makes a bit of a difference. They have a hard time playing some ripped discs. mine has performed flawlessly for years.
Post Mon Sep 19, 2011 3:52 pm
TNRabbit wrote:I run mine with an outboard DAC, which makes a bit of a difference. They have a hard time playing some ripped discs. mine has performed flawlessly for years.
I saw Gary's and it looks really good. His also sounds really good, but he does use that great external BenchMark Dac.
Post Mon Sep 19, 2011 4:20 pm
A computer CD drive would sound good with a Benchmark DAC.
mjcmt
Post Tue Sep 20, 2011 6:59 pm
I agree, the Benchmark DAC will make most lowly digital sources sound wonderful. A few years back I used one with one of the early Oppo players, the dv970hd, and it sounded detail and involving and very 3 dimensional. I ran its variable out direct to a tube power amp w/ an very convincing sound. I also used the digital optical out of the tv into it for great tv programming sound. This was a nice system except for the tube amp ran many hours a day for tv.
FredRydr
Post Mon Oct 24, 2011 11:52 pm
I've had my SD/A-360 since new, connected to an MXR130 that I had even longer. It's served me well. Today, I hooked it via optical cable (for the first time), but to a hybrid Digital to Analog tube Converter made by Peachtree, and it sounds great.
Unfortunately, when I moved it around, I did something to the tray and it gets hung up the last 1/8 inch, and reopens. I hope it's an easy adjustment.
Fred
Post Wed Oct 26, 2011 11:55 pm
I'll bet it's the trim on top, above the tray. I had it happen to me on two of them. Check it out !
FredRydr
Post Thu Oct 27, 2011 3:02 pm
Mr. M-500t wrote:I'll bet it's the trim on top, above the tray. I had it happen to me on two of them. Check it out !
I even took the cover off and ran the tray in and out. I looked for an obstruction, and it looked like that trim piece, except that the try would stop just shy of it. Sometimes it closes; sometimes not. The guides/bumper on the rear are not an issue. I wonder if there is a rail that needs lube, or some slight adjustment. Anyone have a service manual? Perhaps there's one online. I'm better at mechanics than electronics.
I am beginning to suspect it might be the weight on top of it. The MX130 used to be on it without a problem, but now there's more. I'll start looking for a shelved case to sit on the desk, to take the weight off the SD/A-360.
Fred
