It is currently Wed Jun 19, 2013 1:40 am
Best TFM for LaScalas?
Post Sat Oct 08, 2011 12:13 pm
Re: Best TFM for LaScalas?
Get a tube amp.
Ion
Post Sat Oct 08, 2011 12:38 pm
mbskeam wrote:get the 45 fixed....
you can find a workin 25 for the cost off get this one fixed.
whats wrong with the 25, 45?
I believe its the power supply for the 25 and when describing the deafaning squeal the 45 puts out to left channel after about 15 minutes of running, Rolland immediately knew the problem. Since I'm not too tech-savvy, and its been a little while since the diagnosis, I don't recall what he said.
It was estimated around $300.00 to do a "refresh". And although you might be right about finding a used 25 for around same price, one never knows condition and since it will be old, I'd feel better with a refresh option, knowing all would be updated and in some instances, better than new.
Post Sat Oct 08, 2011 12:41 pm
That makes the most sense.
Post Sat Oct 08, 2011 12:42 pm
Good choice partner ! Roland is held in very high regard around these parts. 8)
Post Sat Oct 08, 2011 12:43 pm
F1nut wrote:Get a tube amp.
Not everybody has your DEEP pockets Jesse ! :rolleyes:
Post Sat Oct 08, 2011 12:48 pm
no we dont...... :-" :-"
but what the hell, it's only $$$$$$$ right :D
back to overtime now..... :shock:
Post Sat Oct 08, 2011 12:56 pm
What Jesse said! You will NOT even look back! :D
Post Sat Oct 08, 2011 12:58 pm
I's just saying ! :lol:
Post Sat Oct 08, 2011 8:16 pm
Even better. Tube amps are not that expensive, if you know what to look for. Plus, you can roll the tubes to help achieve the sound you prefer.
Yes, the TFM15cb has the best overall sound [sonic signature] of the TFM lineup from what I have had first hand experience with. I have heard them all and with the speakers he has, the TFM15cb has all the power his speakers will ever need. Hell, those speakers could run loud and sound great on an 8 watt tube amp.....much like the ones we built up on the mountain at Carverfest. Gotta remember the type of speakers and the efficiency they run at when answering the gentleman's question. He does not need the power of a TFM-75 for what he's got. That would be like trying power a Mazda Miata with a quad turbo jet engine.
It's not like he's trying to power a set of Original Amazings, Apogees, Martin Logans or the like.
rah wrote:As a Klipsch Chorus II owner happily powered by a Sunfire 300 x 2, the one thing I wish I had was a gain control on the Sunfire, which several of the Carver amps do have.
The Chorus's get real loud real quick. Would like a wider volume range to work with.
His speakers are the same way and the amp I suggested has the gain controls.
Post Sat Oct 08, 2011 8:25 pm
Remember, everybody doesn't like the sound of tubes. Audition a tube amp then make your decision.
