It is currently Sat May 25, 2013 2:26 am
Tfm55?
2-tall
Post Sat Nov 19, 2011 11:21 pm
Tfm55?
I am currently running two TFM24's to power my Carver AL111's. I have an opportunity to pick up a TFM55 for around $500.00.Will it be an improvement over the 24's and is it worth the $.
Thanks
Post Sat Nov 19, 2011 11:28 pm
Re: Tfm55?
Yes
Post Sun Nov 20, 2011 4:13 am
Re: Tfm55?
Big time improvement.
Post Sun Nov 20, 2011 7:53 am
Re: Tfm55?
Big improvement over the 24.
2-tall
Post Sun Nov 20, 2011 10:25 am
Re: Tfm55?
I was not sure that one amp meaning the 55 would be better than the two 24's. What kind of improvement should I hear. I listen to everything from jazz to blues to rock.
Post Sun Nov 20, 2011 11:31 am
Re: Tfm55?
2-tall wrote:I was not sure that one amp meaning the 55 would be better than the two 24's. What kind of improvement should I hear. I listen to everything from jazz to blues to rock.
The 55 is a true magnetic field amp unlike the 24's. If you can supply the amperage with a dedicated circuit the difference will be very noticeable if you have revealing source and speakers. I have 3 and have compared them to the TFM-25 of my friends. No contest.
PDR
Post Sun Nov 20, 2011 11:37 am
Re: Tfm55?
Ive never heard a 55, but I have a A760x......are they close in sound or is one better than another?
Post Sun Nov 20, 2011 11:49 am
Re: Tfm55?
I've had both but never side by side. The 760x is very powerful but not as musical in my opinion, same with all the THX amps, kind of flat sounding but very clean and powerful. I think they're so clean that it takes some of the life away.
Post Sun Nov 20, 2011 11:58 am
Re: Tfm55?
Yes,,but a Sunfire is the way to go bar none. I have two 55 amps and know this first hand.
Post Sun Nov 20, 2011 12:18 pm
Re: Tfm55?
No argument there angelo! In fact there's a 300x2 on Audiogon right now for $600. I've been very tempted to "upgrade" my brothers birthday present at that price! ](*,) ](*,)
tfm carm
Post Sun Nov 20, 2011 7:51 pm
Re: Tfm55?
I have a tfm 55 & love it I actually had 2 now I have 1 along with a tfm35 my question is is the tfm 35 a true magnetic field amp like the tfm 55?
Post Sun Nov 20, 2011 8:44 pm
Re: Tfm55?
No!
Post Sun Nov 20, 2011 9:41 pm
Re: Tfm55?
yeah, what he said, no. still very nice though.bob and his assistant spent alot of time back and forth overseas for the final production models. they are otherwise the same other than power supply. 3 rail design.
Post Sun Nov 20, 2011 9:50 pm
Re: Tfm55?
So the 25 AND 35 are not magnetic design? :-k They advertise them as such. I always knew the 6 & the 15 were not but the 35?
Post Sun Nov 20, 2011 9:52 pm
Re: Tfm55?
8-ohm FTC rated power/ch 250 W
4-ohm FTC rated power/ch 380 W
2-ohm dynamic power/ch 560 W
Bridged mono power 700 W
4/8-ohm FTC rated THD 0.5 %
Rated full power bandwidth 20-20kHz
S/N-IHF A-Weighted,dB 98
Dimensions (HxWxD inches) 4.5x19x14.5
Comments Stereo or bridged mono
Simultaneous High Current/High Voltage Magnetic Field Power Amplifier. Eminently affordable and yet astonishingly powerful, the TFM-35 is designed to drive many popular speaker designs whose overall impedance fluctuations can tax conventional amp designs. Transfer Function Modified to provide the warm, natural sound of a tube amplifier. 250 watts per channel into 8 ohms. 380 watts per channel into 4 ohms. 560 watts per channel into 2 ohms. 700 watts bridged mono. Patented Magnetic Field Power Supply provides extraordinary power from a compact design. Features analog power meters with meter range switch. Concentric left/right level controls. Special circuitry to protect both the amplifier and loudspeakers from overload.
:-k :-k
